Buzzing sound from locker bypass
I just installed the Able component per instructions, everything worked great but when I am driving in two wheel drive with the rear locker off. I am getting a intermittent buzzing sound from the control box. Any ideas why.
Re: Buzzing sound from locker bypass
Under Marketplace, Vendors,Abel components section are discussions that may help,,,,also the e-mail to go direct to Abel if you still have ?
Review the instructions - a simple adjustment will fix that...
