There's lots of em rolling around my area now. Good that they're selling them but I liked being in a "not run of the mill" truck. I was the only one you'd see regularly 5 yrs ago. Now I see 3 every day and have counted around 25 different ones.
Dodge Ram Power Wagon Global Production Numbers 2005-2015
- jeep_boy02
Re: Dodge Ram Power Wagon Global Production Numbers 2005-2015
Yep I see lots in my region, I see increased popularity as a good thing as it means increased aftermarket support.jeep_boy02 wrote: ↑Sun Jul 11, 2021 5:54 pmThere's lots of em rolling around my area now. Good that they're selling them but I liked being in a "not run of the mill" truck. I was the only one you'd see regularly 5 yrs ago. Now I see 3 every day and have counted around 25 different ones.
@PLMCRZY, I’ll be interested to see the 2021 production numbers, and how many were 75th Anniversary Editions
- jeep_boy02
That is true... I really wanted to order an anniversary but once I found out they have an electronic 4x selector knob I was immediately out. I don't care for the axle disco and I definitely want a manual lever select tcase.
Believe those may be/available as deletes if I understood things correctly!
- jeep_boy02
2010, rarest of the 4Gs, glad I've kept mine. Anyone know if there's any info breaking down numbers by paint codes?
That’s the first I’ve heard that you could get a 75AE with manual transfer case... I’d be surprised if that was true because they all have the special colored leather bucket seats, no bench seats.
The the flip side, the electric transfer case was an option on “regular” 2021 Power Wagon but with bench seat still.
Coder, in Engines & Drivetrains, early Feb 2021 posted it was going to be available in the 75AE in a “no more T case manual shift”. Uncertain of his source,,,,was why I qualified my comment.
Any Idea of breakdown per color of the 2016 models?
Mine is Blue Streak Pearl and I am wondering how many were made out of the 502 built in 2016.
I had a hard time finding this truck in this color....
