Camper/Toy Hauler Advice
Re: Camper/Toy Hauler Advice
My Outback wasn't like that. I could carry a full load.
Maybe they improved over the years, IDK. Maybe Keystone Tail Gator was a shitty brand, IDK. I can tell you it was one of the first things I checked on our current camper & was glad to see it had actual angle iron supports. Also, not sure how much you guys know about water. I learned quite a bit while in the US Army & in my lifetime. Water filters are NOT water purifiers. 2 totally different things. 99% of Water filters do not filter out bacteria & virus's (which is what makes you sick). Most just filter out sediment, minerals & bad taste. 20-25 microns is the norm for particle size filters. I use a 5 micron sediment & a carbon filter for taste in my whole house water filters. It does affect water pressure. It helps keep the washing machine, dishwasher, shower head, faucets & ice maker from plugging up when they flush the hydrants & keeps the chlorine taste from being bad. To get to remove bacteria & virus's, you really need a 0.2 micron filter. Not practical at all in a whole house or camper system. Water pressure would be almost nil.
https://www.bigberkeywaterfilters.com/
https://www.youtube.com/watch?v=3F6Y3cDsSL8
The Pro's: They are portable, work on gravity, work with tap water, work with pond water, work with river water. They are purifiers.
The con's are: they take up counter space, cost more initially.....yet are cheaper long term. IMHO, the cross contamination issue addressed in the vid can be solved with a clean garbage bag & some vacuum line caps on the filter discharge nipples, like these https://www.summitracing.com/parts/trd- ... gJ9CfD_BwE .
Just putting this stuff out there for everyone to know. No one wants to get sick while enjoying the great outdoors. Algae & bacteria can also grow inside fresh water tanks & pipes of RV 's. We never drink the water from the camper, just do dishes with it. I also sanitize the system every spring with plain old bleach. No scents or dyes or concentrated formulas. Plain old bleach & water.
I have two filters. One is sediment and second one is carbon, etc.
I use a 2 filter set-up in my motorhome. For drinking. I use bottled water.
And that. Use bottled water for drinking.RustyPW wrote:I use a 2 filter set-up in my motorhome. For drinking. I use bottled water.
So I’m curious if the OP ever bought a travel trailer? Any updates?
I have a Prine Time Fury 2910! 4000watt Cummins/Oman lp generator with remote prime/start, 600w solar, 78gal fed, GW40gal, BW40...
29’ living area(10’garage), 34 1/2’ total length!
11,000+Lb fully loaded, <1000lb TW! 12,0000 equal-I-zer WDH, Airlift 5000 bags, Daystar cradles w/remote!
Tows well for me at speed with RZR 900 and full water tank and 2 lp tanks!
Who was the member?
He didn't give me the details. Now that I think of it he may have had an 05. It was darker silver.
