35 x 12.50 x 17 Wheel Width Question (10")
mdahs
Post by mdahs » Thu Mar 10, 2022 4:07 pm
Good Afternoon Everyone! I'm new here, this is my first post. I have a 16' Power Wagon w/ factory suspension. I'm due for new tires and looking at going with a 35 x 12.5 x 17 to give the truck a more aggressive stance. I currently have AEV 8.5" Salta's but I'm considering going with AEV 10" Kalta's to simply to add more of an wider stance. Does anyone have experience with a 10" wheel in a similar configuration? I'm curious to see if I will get any rubbing or if this will even help achieve the "more aggressive" look? I do not want any rubbing and I'm not willing to trim, any advice is greatly appreciated!
I live in NW Montana so the truck sees a lot of old logging roads and gravel roads (lots of snow & Ice too, but I have dedicated studded winter tires). I'm considering Mickey Thompson Baja Boss AT's as a tire choice, but feel free to weigh in on that as well if you'd like.
And because we all like to show off a bit, I've attached a picture of the truck!
Re: 35 x 12.50 x 17 Wheel Width Question (10")
Post by Bill2014 » Tue Jul 12, 2022 11:14 am
All the info you are asking for can be found here:
https://www.thurenfabrication.com/pages ... el-fitment
good luck
Post by TankerZak » Tue Jul 12, 2022 12:17 pm
If I remember right the 10 inch AEV wheels are designed to run 40s so the offset will be wrong for 37s. Basically it will push them out too far and cause them to rub badly because you aren't doing all the trimming and hacking along with AEV flares that 40s require.
