Hi, need help
iowa
Model Year: 2019
Hi, need help
Post by iowa » Sat Nov 21, 2020 2:19 am
http://www.hypertech-inc.com/vehicle-re ... AID=527374
Will this work on new model PW to correct the speedo and shift points? I’ve read some confusing posts regarding a bypass for newer trucks?
Thanks for any help. Excited to be a new member of the forum!
2020 RAM Power Wagon
Level 2 equipment group, RokBlokz, BakFlip MX4, AEV Procal Snap
IG @ iowa_wagon
Re: Hi, need help
Post by Mule007 » Sat Nov 21, 2020 10:49 am
Welcome to the forum, Enjoy 🌞👍 !! Retired BLM is probably your best resource for this answer !
2005 Mineral Gray;QC, #0666: “Laramie”, Leather, power/heated seats, mirrors, dual control zones, Alpine 9 speaker surround sound, steering wheel cruise, music & volume controls, 6 CD player, AC; dark charcoal silver interior.
Updates: New Jasper Remanufactured 5.7 Hemi Engine (3 yr/100’000 mi warranty), Open Range All Terrain 35 x 12.5 x 17 MP3 10 ply E tires; McQuay-Norris Extreme ball joints; driveline u joints; fuel pump; 1 ton HEMI transmission cooler; OEM radiator; new front pinion seal & bearing; Denso 180 amp alternator, Interstate Mega-tron 850 CCA HD battery; water pump & serpentine belt; Bilstein 2 5100 shocks & steering damper.
pdavey
Re: Hi, need help
Post by pdavey » Sat Nov 21, 2020 12:12 pm
I have not seen a programmer that will work with the 19+ trucks yet. You would definitely need the security bypass cable. I wrote up a thread on where to find it. Will try to locate the thread and post it here.
Performance Mods:
Other Mods:
Suspension/Protection Mods:
Style/Other Mods:
pdavey
Re: Hi, need help
Post by pdavey » Sat Nov 21, 2020 12:15 pm
https://r.tapatalk.com/shareLink/topic? ... source=app
The programmer I reference can help to change the speedo.
I also got the security bypass cable for the AlphOBD so I could enable a few features on the truck.
Performance Mods:
Other Mods:
Style/Other Mods:
iowa
Model Year: 2019
Re: Hi, need help
Post by iowa » Sat Nov 21, 2020 2:10 pm
So the correct location for the new PW bypass should be in front of your knee and not behind the gauge cluster or radio correct? Sorry for all the questions. pdavey, the kaodtech bypass looks simple enough to use a Hypertech, Tazer, etc to correct for tire size.
The AEV procal snap seems to have an easy install, but there were issues with some PWs, but some were just fine... supposedly they are going to correct it and rereleased for PWs.
I’ll get to reading/researching. Thanks everyone!
IG @ iowa_wagon
pdavey
Re: Hi, need help
Post by pdavey » Sat Nov 21, 2020 2:14 pm
Yes if you get the koadtech or aev it is the green bus bar near your knee. If you need to do a bypass it is behind the instrument cluster.
Performance Mods:
Other Mods:
Style/Other Mods:
