FNG w/2017 PW
Extrapale
FNG w/2017 PW
Post by Extrapale » Sat Feb 22, 2020 12:57 pm
I'm new here. I have a 17 PW that I have owned since new. Still stock except 285 75 17 Coopers replaced the Goodyears.
Still trying to figure out if I like love or hate the truck. I had a 2004 CTD HO with manual for 13 years prior to this. I definitely hate the auto tranny in the PW. I am starting to look at tuners to maybe improve things.
Regearing may help also. It seems to tall for towing and putting around the desert.
He is a pic of the truck when new. It had 50ish miles on it and I took it out to SE Oregon to bow hunt deer.Image
Sent from my LM-G820 using Tapatalk
Re: FNG w/2017 PW
Post by olyelr » Fri Feb 28, 2020 6:54 pm
Welcome to pwr!
Re: FNG w/2017 PW
Post by Bill2014 » Fri Feb 28, 2020 9:00 pm
Re: FNG w/2017 PW
Post by Mule007 » Fri Feb 28, 2020 9:18 pm
Looks like you found or redid your first post !
NEW: “Bear”: 2015 Ram 2500 Tradesman 4WD, Crew cab, 68K miles; 2nd Owner-Power steering, windows, brakes, Tip start, heated tow mirrors; Sirius, blue tooth, Alpine 6 speakers; 35% tinted windows, Black, diesel gray, silver interior; Systems: Driver Info Displays; TPMS, ESC; Power converter; AC; ERS controls on shifter. Anti theft system, vehicle immobilizer. Engine: 6.4L Hemi, Auto. HD 6-66RFE-6 speed transmission; 3.73:1 gears; 1 ton Hemi transmission oil cooler; 2-speed electric shift BW44-46 4WD shift on fly; Trans. skid plate. Axels: F-5,500 #; R-6,100#; Solid front, Anti- slip differential rear; Tow Pkg:: Rough Country 2.5” lift; Tekonsha Prodigy P2 trailer brake, HD Coil Springs, Bilstein B8 5100 shocks, WD hitch, F/R HD stabilizer bars; rear track bar; sway control; Tow Haul Mode, brake assist, Hill control;recalls; 5” oval SS steps; Brakes: Extreme Z36 Truck and Tow Drilled/Slotted F&R rotors & pads; Wheels: XD KMC235 Grenade Crawl bead-lock wheels;
Extrapale
Re: FNG w/2017 PW
Post by Extrapale » Sat Feb 29, 2020 11:44 am
Thanks for the welcome.
First post shoed up after a couple days.
Re: FNG w/2017 PW
Post by RustyPW » Sat Feb 29, 2020 2:44 pm
:winchmob:
