Post
by 05PWrockcrawler » Wed Jul 29, 2015 7:40 pm
Colibri wrote:Hello everybody! New here, just registered. I know a few of you from the DTX. I have an 09 QCSB that's a work in progress. Glad to be here!
Hey I'm trying to get in contact with you! Thanks Jeff
Post
by 2wagons1driveway » Thu Jul 30, 2015 11:39 pm
05PWrockcrawler wrote:Colibri wrote:Hello everybody! New here, just registered. I know a few of you from the DTX. I have an 09 QCSB that's a work in progress. Glad to be here!
Tim paging Tim! I'll text him Jeff see of we can gather his attention lol
Post
by 05PWrockcrawler » Sun Aug 02, 2015 2:12 pm
Got a hold of him thanks.
israelstanage
Post
by israelstanage » Sun Aug 02, 2015 3:54 pm
Relatively new owner from Kansas. Need a truck for work and am loving my first 3/4 ton. Most of my off road time comes in bow season. I will have the new rig in the mountains above Meeker in a few weeks chasing elk and bear.
Cactus Red
Post
by Cactus Red » Mon Aug 03, 2015 12:03 am
Good luck with the truck and the hunting!
Post
by 2wagons1driveway » Mon Aug 03, 2015 11:26 am
israelstanage wrote:Relatively new owner from Kansas. Need a truck for work and am loving my first 3/4 ton. Most of my off road time comes in bow season. I will have the new rig in the mountains above Meeker in a few weeks chasing elk and bear.
these trucks are usually way more then you'll ever need to do excursions off the beaten path. Offroad stock ride quality is amazing I would suggest running the truck in 4hi and disconnecting the swaybar when in really bumpy slow terrain really takes the shake out of the cab over very uneven chopped out logging roads.
israelstanage
Post
by israelstanage » Mon Aug 03, 2015 12:00 pm
2wagons1driveway wrote:israelstanage wrote:Relatively new owner from Kansas. Need a truck for work and am loving my first 3/4 ton. Most of my off road time comes in bow season. I will have the new rig in the mountains above Meeker in a few weeks chasing elk and bear.
Any issues with disconnecting sway bar while towing? The path up the mountain is pretty rough, and I will be dragging a heavy duty trailer with 3 suvs, as well as misc camping gear.
esloar71
Post
by esloar71 » Mon Aug 03, 2015 12:25 pm
Greeting everybody,
Just purchased a 2007 PW. I have got my list together yet of things I want to do other than replace the winch which is missing.?? It doesn't look like it was even there. Previous owner put 35s and glass packs on it. It's hard to stay off the gas with the 6 speed. I can't wait for the snow here in Upstate NY. I'll be stopping every once in a while
Eric
Pics will follow.
Post
by FirerescuePW » Mon Aug 03, 2015 12:29 pm
It will only remain disconnected under 19 MPH, so it shouldn't be a problem. You can disconnect it and just leave it alone. It will reconnect if you go over 19, and then disconnect again when you drop below.
Post
by olyelr » Mon Aug 03, 2015 2:24 pm
Can you even disconnect in 4 hi, regardless of speed? I know you cant with the Jeep rubicon.
Post
by cruz » Mon Aug 03, 2015 3:23 pm
olyelr wrote:Can you even disconnect in 4 hi, regardless of speed? I know you cant with the Jeep rubicon.
Yes
Post
by RustyPW » Mon Aug 03, 2015 9:39 pm
esloar71 wrote:Greeting everybody,
Eric
Pics will follow.
Welcome to the forum.
Every PW comes with a winch. The owner before you took it off and sold it for extra money I bet. We see this alot.
My build thread.
http://forum.powerwagonregistry.org/vie ... =13&t=2826
Post
by Low_Sky » Wed Aug 05, 2015 4:01 pm
You can. And the truck will remember your sway bar setting if you switch from 4hi to 2wd and back to 4hi.
I use 4hi with the sway bar disco'ed on dry, bumpy/rutted roads, and throw it into and out of 2wd for tight corners. The disco really smoothes the ride out, very noticeable. I wish the sway bar would disconnect in 2wd.
Post
by 2wagons1driveway » Wed Aug 05, 2015 4:14 pm
That's why the Thuren fab swaybars and Carli swaybars rock so much ass^^^^^^ much softer and takes that slap out if the truck when offroad but still give you lots of control at speed.
llsht14
Post
by llsht14 » Thu Aug 06, 2015 11:52 am
New here, just sold my megacab laramie 2011 cummins for a 2015 power wagon. Will see how i like the gasser life again, would love to get a locker bypass harness, anyone know how i can get in direct contact with someone for that?
outwardbound
Post
by outwardbound » Thu Aug 06, 2015 1:59 pm
New here as well. Crossed over from Toyota Tundra land and a life of Land cruisers, Tacos, Tundra's, and 4runners. Loving the new 15' PW I just got in Maximum Steel Metallic. The truck drives great on and off-road. Only 400 miles on it so far. I do hope I don't have to experience the "death wobble" I keep hearing and reading about. Any advice on how to avoid it or prevent it (other than not drive the truck)?
Thanks.
outwardbound
Post
by outwardbound » Thu Aug 06, 2015 2:51 pm
New here. Just crossed over from the Toyota realm after numerous land cruisers, 4runners, Tacos, and Tundra's over the course of my life. This is my first Ram and my first heavy duty pickup. Looking forward to exploiting all that the PW has to offer. I do hope the reliability measures up thought. I keep hearing about Ram 2500 Death wobble in the 2500s and the PWs especially. ANy advice on how to avoid? I've only got 400 miles on my 2015 PW and hope to get at least 100400 before I I see any issues.
Post
by 2wagons1driveway » Thu Aug 06, 2015 10:35 pm
outwardbound wrote:New here as well. Crossed over from Toyota Tundra land and a life of Land cruisers, Tacos, Tundra's, and 4runners. Loving the new 15' PW I just got in Maximum Steel Metallic. The truck drives great on and off-road. Only 400 miles on it so far. I do hope I don't have to experience the "death wobble" I keep hearing and reading about. Any advice on how to avoid it or prevent it (other than not drive the truck)?
Thanks.
probably won't have much issue with death wobble seems few and far between with radius arm trucks
Post
by RustyPW » Thu Aug 06, 2015 10:53 pm
Welcome guys.
My build thread.
Post
by FirerescuePW » Fri Aug 07, 2015 10:54 am
Welcome everyone!
Allen8511
Post
by Allen8511 » Sat Aug 08, 2015 4:37 am
Hello all,
Not my first Dodge product, but my first Ram truck. As much as it hurt to do, I just traded in my Rubicon for this great truck. I was looking for a more utilitarian vehicle for my family and one that meet my wheeling requirements. So I got a 2015 Power Wagon Larmie. So far, I love it. I've never owned a nicer and more beastly vehicle. This forum has a wealth of info. I do have one question. How come I can register on the forum but not the main page/registry?
Thanks,
Allen
Pit Slave
Post
by Pit Slave » Sat Aug 08, 2015 9:36 am
The registry was created years before the forum was. The two have never really been merged together. They are basically two separate sites that are under the same entity. Leif started the forum as a place where we can all be together to share our knowledge and learn more about the Power Wagon, in a free and open environment. We have GTG's through out the US and Canada where we meet up and/or go off road/wheeling(also one of the reasons the forum was started).
Welcome everyone!
Allen8511
Post
by Allen8511 » Sat Aug 08, 2015 12:14 pm
Pit Slave, thank you. That makes perfect sense. Hopefully my registration gets accepted on the registry.
Post
by 2wagons1driveway » Sun Aug 09, 2015 2:07 pm
This is a great site to learn. If you have any questions I highly suggest searching around a bit first. There's multiple discussion on tire size mods and what not for the 4.5/5th gen radius arm wagons
Post
by 05PWrockcrawler » Sun Aug 09, 2015 7:15 pm
Welcome to the family. The PW is a Cadillac compared to a rubicon. Lot more comfortable to ride in. Hope to see you on the trail!
