Introduce
Re: Introduce
Welcome to the forum!
, Enjoy!, Lots of good info here, & the members are real helpful if you have questions. Where you from? Year of your truck?
Additions: Frame mounted .188 DOM 3" steel rock rails, low profile steps;1.5” Skyjacker leveling kit; Bully Dog GT Platinum A-pillar mount programmable performance chip, monitor,& tuner; Linex Platinum OTR HD bed & rock panel coating; Red Ryder cab high fiberglass canopy; 2” Linex brush guard w/4-4” Halogen off road lights; Hopkins Trailer Mate brake controller; Bearcat Pro 68XL CB; Mopar black fender flares; PW winch accessory kit/remote control.
Re: Introduce
Re: Introduce
Hi all I live in Pitt Meadows BC I have a 2005 Power Wagon. I have had it since 2008
Re: Introduce
Welcome to the forum.
Enjoy the drive.
Re: Introduce
Welcome to the forum, Enjoy
Re: Introduce
Welcome to the Group !
Re: Introduce
bsqui ...What number is your truck? I think it is the last 4 or 5 numbers of the VIN.
#992 for me.
#992 for me.
