Just picked up a fully loaded 2020 power wagon. Coming from a 2015 1500 ram, rides smoother than my old 1500. We live out in the bush do a lot of hunting lots of dirt roads on our normal commute I figured the power wagon is exactly what we need.
Any do’s and don’ts on this power wagon? I was fed up with my 1500 I had bilstein level on it with 35” tires and it went through a lot of front end parts including stripping out the output shaft on the front diff, rams fix? Replace the whole front diff because they don’t sell that particular shaft. It was stuck in 4 low coming back from hunting wouldn’t electronically shift back to 4 high. One thing after the next exhaust manifold studs broke twice no more ac ect.. it was time to trade it in so here I am found my way to this forum.
New owner from Canada
Just picked up a fully loaded 2020 power wagon. Looking forward to reading up all mods/do’s and don’ts/ others experience with it.
I’m coming from a 15’ ram 1500 had enough with working on it and mods making it less reliable (level with 35” tires)
Re: New owner from Canada
Welcome to the forum, Enjoy
!!NEW: “Bear”: 2015 Ram 2500 Tradesman 4WD, Crew cab, 68K miles; 2nd Owner-Power steering, windows, brakes, Tip start, heated tow mirrors; Sirius, blue tooth, Alpine 6 speakers; 35% tinted windows, Black, diesel gray, silver interior; Systems: Driver Info Displays; TPMS, ESC; Power converter; AC; ERS controls on shifter. Anti theft system, vehicle immobilizer. Engine: 6.4L Hemi, Auto. HD 6-66RFE-6 speed transmission; 3.73:1 gears; 1 ton transmission oil cooler; 2-speed electric shift BW44-46 4WD shift on fly; Trans. skid plate. Axels: F-5,500 #; R-6,100#; Solid front, Anti- slip differential rear; Tow Pkg:: Rough Country 2.5” lift; Tekonsha Prodigy P2 trailer brake, HD Coil Springs, Bilstein B8 5100 shocks, WD hitch, F/R HD stabilizer bars; rear track bar; sway control; Tow Haul Mode, brake assist; Hill control; recalls completed; 5” oval SS steps; Wheels: XD KMC235 Grenade Crawl bead-lock wheels;
Welcome to the forum.
Welcome to the Group!
Welcome to the group!
