Hey Power Wagon people!
I am a first time Power Wagon owner from Antigo Wi.
I recently bought a 2018 PW brand new, first brand new truck i have ever owned
I look forward to getting to know this sight and many of you, and hopefully to join you in some wheelin!
Here is a picture from my trucks first off road outing up in Crooked Lake WI
it was a blast and i look forward to many more days like this!
Hello from WI
Re: Hello from WI
Welcome, if you do a lot of water may want to
check the threads for snorkels & high feed filter set ups! Enjoy !!
check the threads for snorkels & high feed filter set ups! Enjoy !!NEW: “Bear”: 2015 Ram 2500 Tradesman 4WD, Crew cab, 68K miles; 2nd Owner-Power steering, windows, brakes, Tip start, heated tow mirrors; Sirius, blue tooth, Alpine 6 speakers; 35% tinted windows, Black, diesel gray, silver interior; Systems: Driver Info Displays; TPMS, ESC; Power converter; AC; ERS controls on shifter. Anti theft system, vehicle immobilizer. Engine: 6.4L Hemi, Auto. HD 6-66RFE-6 speed transmission; 3.73:1 gears; 1 ton transmission oil cooler; 2-speed electric shift BW44-46 4WD shift on fly; Trans. skid plate. Axels: F-5,500 #; R-6,100#; Solid front, Anti- slip differential rear; Tow Pkg:: Rough Country 2.5” lift; Tekonsha Prodigy P2 trailer brake, HD Coil Springs, Bilstein B8 5100 shocks, WD hitch, F/R HD stabilizer bars; rear track bar; sway control; Tow Haul Mode, brake assist; Hill control; recalls completed; 5” oval SS steps; Wheels: XD KMC235 Grenade Crawl bead-lock wheels;
Re: Hello from WI
Welcome to the Group!
Also for deep water situations - check the forum for info on rerouting your vent lines a little higher!
astrayer1990
Re: Hello from WI
Mule,
I don't do alot of water, it just looks way deeper than it is and i came in a little hot.
But it was one of the coolest photos of the day, so i couldnt not share!
Re: Hello from WI
Welcome to the forum.
