New 2005 Power Wagon Owner
Hey guys!
Excited to find this forum and have a power wagon finally.
Like most I have the following issues:
1. My SERV 4x4 light is on, my RR locker switch blinks fast and never engages and so does my sway bar disconnect.
2. My four wheel drive works and my rear locker seems to work as well. But I don't think the sensor is working to say its locked so the front locker will not engage. What are my options? (I also looked in the smart bar and it appears to be clean with all the pins in the correct place.) Wiring short or break from rear lockers back to front??)
-Sam
2018 Zr2 Duramax
-Sam
2018 Zr2 Duramax
Re: New 2005 Power Wagon Owner
Transfer case position sensor is a good place to start looking.
The lockers and sway bar need to know the truck is in 4LO to work, so a faulty TCPS will throw errors and prevent that stuff from working right.
Hello sdeen45,sdeen45 wrote: ↑Thu Jan 31, 2019 11:27 amHey guys!
-Sam
2018 Zr2 Duramax
Here are a couple of possible areas to look at:
1) The rear locker actuator needs replaced it will cause the swaybar disconnect to not engaged because of the error from the rear locker, mine needed replacing here's a link to the post with all the gory details.
2) The front swaybar disconnect might be bad the 2005's sway-bar disconnect's controller is different than the 06-09's I believe the locker electronics are dependant on it and won't work correctly if there are problems.
I had to replace my rear locker actuator, serval other have as well, here is the link to the post on it for reference:
viewtopic.php?f=2&t=5085
honestly once you have this sorted out, your going to have one seriously clean 2005.
congrats
congrats
Thanks guys,
I'm going to check my Transfer Case Position Sensor and check back in!
-Sam
-Sam
Here's a troubleshooting/repair post on the transfer case position sensor for reference:
viewtopic.php?f=2&t=2793&p=41848&#p41845
Changed the Transfer Case Position Sensor and all is working now!! Thanks guys!!!!!
Congrats! Welcome to the forum, Enjoy
!,NEW: “Bear”: 2015 Ram 2500 Tradesman 4WD, Crew cab, 68K miles; 2nd Owner-Power steering, windows, brakes, Tip start, heated tow mirrors; Sirius, blue tooth, Alpine 6 speakers; 35% tinted windows, Black, diesel gray, silver interior; Systems: Driver Info Displays; TPMS, ESC; Power converter; AC; ERS controls on shifter. Anti theft system, vehicle immobilizer. Engine: 6.4L Hemi, Auto. HD 6-66RFE-6 speed transmission; 3.73:1 gears; 1 ton transmission oil cooler; 2-speed electric shift BW44-46 4WD shift on fly; Trans. skid plate. Axels: F-5,500 #; R-6,100#; Solid front, Anti- slip differential rear; Tow Pkg:: Rough Country 2.5” lift; Tekonsha Prodigy P2 trailer brake, HD Coil Springs, Bilstein B8 5100 shocks, WD hitch, F/R HD stabilizer bars; rear track bar; sway control; Tow Haul Mode, brake assist; Hill control; recalls completed; 5” oval SS steps; Wheels: XD KMC235 Grenade Crawl bead-lock wheels;
Welcome to the forum.
Glad you get it fixed. And not spend a boat load on it.
Welcome to the group!
