Back on the wagon
Moderator: myoung84
Re: Back on the wagon
Hopefully Shelby will be able to get these built for you guys. The funny thing is I still have my locker bypass sitting in a box in my garage. I really need to get around to installing this thing some day.
He did contact me.. And said no later than Monday for shipping out.
I will also add that if he showed me the ways... I would help make these for a cut
I got a photo of shipping receipt sent to me the other day. Will post when it arrives at the house.
Double post
- Stickman
Received my bypass kit today! Looks like a factory harness and is very well made. May have it on this weekend if nothing comes up, so I'll update in here to let everyone know how easy the install goes.
Dang, I sent an email but never received a response. Bummer.
Question for anybody that knows. How does the traction control react to the lockers being engaged in 2wd and 4 high?
Sent from my XT1080 using Tapatalk
2014 Powerwagon. Stock for now.
1989 Dodge W-250 Cummins. 4" lift, 35's, crossover steering, power mods.
Received mine as well. You might want to check the contents of the relay box before you get ready to install. The adhesive/hot glue used to secure the relays/parts inside the box had come free on mine on pretty much all parts attached to the interior of the box itself. Nothing major, but worth addressing before you set aside some time to install.Stickman wrote:Received my bypass kit today! Looks like a factory harness and is very well made. May have it on this weekend if nothing comes up, so I'll update in here to let everyone know how easy the install goes.
I figure he's got a good sized list to work through. I got an email asking for clarification on my truck year, but no details on timeline. I imagine and hope he's working his way down the list to us. Hopefully we'll hear something fairly soon.Reloaderguy wrote:Dang, I sent an email but never received a response. Bummer.
Just got mine in the mail! Might tackle it this weekend. Thank you Shelby!
I will note that one of the relays also came un-glued.. But no big deal... It was left outside from the mail carrier and maybe this Michigan cold had somthing to do with it.
- Stickman
I cracked mine open and it was indeed rattling around some with the glue broken free. Would I need to stuff something in there after setting the relays to keep everything from coming apart? Looked fairly secured, not much that could come apart with it secured to the truck.
Sounds like there are some minor updates required to the control box.
Keep us posted in installs and fit and finish.
Sent from my iPod touch using Tapatalk
2015 Powerwagon
Locker Mod, 35" Rubber, synthetic rope
Thanks for the feedback on the relays coming loose. I'll make a adjustment to try and prevent that.
thank you for the email! I'll be waiting for you next contact
Got home from work last night and the kit was at the house waiting for me. Now to find some time to install, that is After I use a better adhesive on the relays and circuit boards as they all came loose on the long shipping journey to Canada.
use some RTV silicon, it will take the vibrations better, just make sure the surface is clean and wait for it to fully cure
Mine is for sale. Just sold 2012 PW. Look at classifieds. Mine has no parts that have came loose. MYoungs must of used a better silicone.
- 2011TXPowerWagon
Are you sending emails from "locker bypass" ?CajunPW wrote:Thanks for the feedback on the relays coming loose. I'll make a adjustment to try and prevent that.
Looking forward to feedback on these. I want one...
2015 Powerwagon
2011TXPowerWagon wrote:Are you sending emails from "locker bypass" ?CajunPW wrote:Thanks for the feedback on the relays coming loose. I'll make a adjustment to try and prevent that.
Yes, if you haven't received an email from me please send me one. Thanks
So got my kit installed last night on my 2014. Took about 3hrs with a buddy helping. Installed the box behind the air filter ran the harness along the radiator to the battery then down the fire wall to both front and rear axels. The harness length to the axels were plenty long enough, the "T" harness from the box to the battery was a touch short but it does make it where it needs to go. The instructions indicate to use the supplied harness caps/plugs for the OEM axle connectors once unplugged and new harness plugged in, those caps were not in the box, so I filled them with dielectric grease and taped them up really good. I had reported earlier that some components in the box had come loose during shipping, this was quickly and easily redone using RTV silicone. Inside the box there is 2 slide on pin connectors to the relays the white one has a nice snug fit but the red one I think is the wrong connector as it is extremely loose fitting as you give a shake and it come un done by itself, quick dap of hot glue will keep it place and still be able to disconnect it in the future if needed. The adjusting procedure to set the trim pot resistors is simple and easy to do, just leave attracting the box behind the air filter to last so that you have easy access to it for setting it up, once done put the lid on and screw it in place.
I do need someone to test their stock locker for me please. When engaging both front and rear lockers which lights are coming on the factory dash switch? Right now when both are engaged the front/rear light and the REAR lights are both on. I cannot remember if it was that way when stock or not.
Overall these kits are well made with a lot thought into the design, like with any new parts give it all a good once over before starting to make sure all connections are tight etc.
Thanks again Cajun for building these kits, for the guys worried about loose components in the boxes, it's an easy 5 min fix and I wouldn't let that stop me from buying one.
My 2015 switch lights up the rear when the rear is locked
When they both lock up just the frt/rear light is on
2015 Powerwagon
How do I get ahold of one of these kits...
2015 Powerwagon
Thanks wrench04 appreciate it
At the very start of this thread Cajun has his email address. Send him an email with the info he requires and you are on the list
