We offer more choices than any other company on the planet. Short arms, long arms, non adjustable, single adjustable, dual adjustable, bent, straight, offset... we'll even build something custom for you if you want. The one thing we don't do is make cheap arms. Most are made from 2" OD 1/4" wall 1026 DOM tubing - bigger than anybody else. Our offset upper arms are made from 1.5" OD 1/4" wall 1026 DOM tubing - these are physically the same OD as most "cookie cutter" companies use for their upper and lower arms, however our wall thickness is twice as thick as theirs. We use the largest bushings in the industry - a massive 2 5/8" OD. This means more "meat" where you need it. Many bushings are just a 2" OD which is basically Jeep sized. The outer bushing is made from DOM tubing, and our inner sleeve is also made from DOM tubing - 1" OD. The significance of this is that it's not a flat piece of steel rolled into a circle like you see with BDS and others. This was designed to be a hollow tube from the get-go, we just modify them to fit the bolt sizes on our trucks. They are perfectly round and are about as heavy as a roll of quarters by themselves. All of our bushings are greaseable and if you ever need to rebuild them (we have yet to sell a a rebuild kit in 3 years now) it's a very simple process that can be done in just a few minutes. Here is a side by side shot of a standard bushing (left) and our bushing (right):
A lot of high-end control arms use joints on both ends, but we offer bushings or joints because not everybody needs the strength that joints offer. Bushings are great for those who daily drive their truck but then go out and play on weekends. If you spend a lot of time in wet weather or in colder climates, bushings are great. We had a truck use our cheapest set of arms and go all the way from Maine to the tip of Argentina, and back almost entirely off-road - they only had to grease their arms a few times. We have guys running these in Baja Mexico, up in Alaska and Canada, all over the rest of the country and several other countries too. If you want a good solid set of control arms that just works no matter what you are doing, here you go. And starting at only $399 you aren't going to find a better price for this kind of quality.
Our $399 non-adjustable short arms, both upper and lower are 2" OD 1/4" wall DOM: http://dodgeoffroad.3dcartstores.com/Do ... p_119.html
For those who are running bigger tires or just need more tire clearance, we also offer an offset version of the above arms that will give you an extra 1" of tire clearance. We use the same beefy lower arm and put a bend right in the middle of it, and then we use the smaller OD upper arm and offset it all the way to the inside of the frame. These are just $499 for the set of 4 and will bolt right in with your stock hardware. We sell a TON of these arms and should always have them in stock for the factory Power Wagon suspension height, but we can make custom sets in a few days in most cases. http://dodgeoffroad.3dcartstores.com/Do ... p_120.html
These are our non-adjustable bushing-ended arms for 3rd and 4th gen trucks. We have so many different arm options that I'll do multiple posts as time allows to kind of sort everything out and show you what we have. The above arms are our best sellers because of the price and quality, but everybody has different needs and that is why we offer so many options. I'll update this thread a little at a time and can answer any questions you have along the way.
