Anyone tried any of these tires?
ramv
Post by ramv » Tue Mar 05, 2024 4:22 pm
Anyone tried any of these three? The Toyo RT Trail is new, as is the Falkan RT. I was going to get the Maxxis then these two options popped up, in my size and weight rating. Unfortunately, I don't use my truck the way it should be used very often anymore and I probably should just get the Wildpeak AT3s (had these on a dually we recently sold, they were great tires) or the new AT4. That being said, I want something that looks more aggressive. Currently have Toyo MTs that are starting to look pretty rough (have about 30k miles on them.) Always hate to go backwards in aggressive! (Went from GSAs to X-Terrains to Krawlers to bias ply Iroks in my second gen.)
https://www.falkentire.com/wildpeak/rt
https://www.toyotires.com/rttrail
https://www.maxxis.com/us/tire/razr-mt/
I'm indifferent to ride or noise, but the MTs definitely wear the outer lugs down pretty bad. (And likely are contributing to the being out of balance now.) I know tires are like ice cream, everyone has a favorite flavor, but having recently had Toyos and Falkans, I'm happy with their quality and I seem to have Maxxis on everything else the moves. (Side by Side, mtn bike, etc.)
Chubbs
Re: Anyone tried any of these tires?
Post by Chubbs » Thu Mar 07, 2024 8:36 pm
If you want aggressive styling, low road noise, and 3 peak rating, check out the Mickey Thompson Baja Boss ATs.
I don't have enough miles to give feedback on wear, but the have been great in the snow and are REALLY quiet on the highway for how aggressive they look.
2018 Power Wagon
ramv
Post by ramv » Fri Mar 08, 2024 9:25 am
Unfortunately I don't drive in the snow anymore. (We get maybe one snow day a year in NW OK.)
Post by Mule007 » Fri Mar 08, 2024 9:43 am
My $.02-M 55’s in stock pw sizes, bullett proof in the mountains, skid roads; snow, rain, road. Not a pure mud tire. 35’s have had very good luck w the Open country, Open range 35 x 12.5 x 17,,,mp 3, same performance as the m55’s; Toyo open country AT 3’s close second. Never been hard core extreme 4x4 rock, sand, mud. Ton’s of Oregon blue mtn, Coast mtn, High Cascade mtn logging gravel & skid roads miles,,,bad weather,,,towing 8,000 # travel trailer-almost all Hwy or outback mainline gravel,,,,great performance, warranties, mileage, durability, looks, for our needs. Bro in law swears by the Toyo rt, diesel 3/4 ton, long bed,,,tows a 28’ hitch Trrailer.
ramv
Post by ramv » Thu Mar 14, 2024 5:39 pm
Appreciate it!
ramv
Post by ramv » Mon May 20, 2024 1:51 pm
Got the Toyo RT Trails mounted up. 37" LR E. Exactly 2" taller (36.25") than my 35" Toyo MTs. I also got an alignment done (which led done another rabbit hole on if I should go with Thuren specs. Discount couldn't adjust caster anyway but it was generally within the Thuren recommendations, they put too much toe-in according to Thuren.)
ramv
Post by ramv » Tue Jun 18, 2024 7:32 pm
The 37”s fit really well with the AEV wheels (and Thuren lift)
Just barely kissed the inner fender liner on one of the ribs, pushed them back with some heat. Only around 2” of travel at full lock, anywhere else they cleared with no effort
Getting slightly better mileage than 35”s with the 5.13s.
If I’m ever lucky enough to move back to somewhere with winter I will run oem wheels with 35”s in the winter so I have room for chains. (I have both in storage)
