NH Overland battery mount
Question for those who have installed this. What do you do about the bolt heads being above the bottom of the battery tray? I'm guessing your not setting the battery directly on them.
Re: NH Overland battery mount
Sounds like a poor design. Is there anyway to dimple the metal to recess bolts? Could you use elevator bolts instead?
- SimonandSimonBeast
I would suggest a battery tray pad, and cut out holes where the bolt head are.
