I have a 2021PW ... This was easy on my 2016 anyway with that said, does anyone have any advice or direction on how to hook my light bars up to my Heidi so they can go on and off with my high beams ?
Thanks Jimmy
Light bar connect to High Beam ?
Re: Light bar connect to High Beam ?
I tapped into the positive wire from the left head light to trigger a relay for my driving lights.
Thank you Rusty for your reply. I was just a little concerned as I have done that in the past on my previous power wagons I've had three of them it was a lot easier on the older models my 2021. Everything is recessed in hidden. Guess I'll have to look around for it. Thank you for your response
OceanRescue wrote: ↑Thu Dec 01, 2022 11:08 amThank you Rusty for your reply. I was just a little concerned as I have done that in the past on my previous power wagons I've had three of them it was a lot easier on the older models my 2021. Everything is recessed in hidden. Guess I'll have to look around for it. Thank you for your response
