Tow Hooks
tat6272
Tow Hooks
Post by tat6272 » Sat Jan 26, 2013 11:32 pm
Anyone know what kind of load the front tow hooks are rated for?
Re: Tow Hooks
Post by RustyPW » Sun Jan 27, 2013 12:11 am
Think 5,000 lbs each.
Re: Tow Hooks
Post by 04Ram2500Hemi » Sun Jan 27, 2013 1:19 am
On my 2004 I know it was enough for the tow truck to hook up to them after I slid off the road in the mountains. Once he had me on the road he hooked the other cable to the shackle in my receiver hitch in the back of the truck and spun me 180 degrees to be facing back down the hill. If the Power Wagon hooks are the same I'd say they are pretty damn stout.
tat6272
Re: Tow Hooks
Post by tat6272 » Sun Jan 27, 2013 7:25 am
I wish there was a definitive number. I was trying to pull a log up out of a creek at my buddies farm when I heard a nasty metal POP. Now the one side of my bumper on he side I was hooked up to appears to be hanging lower than the other side. The plastic wheel well liner was popped out of place too, like the bumper had pulled away from the truck a bit.
TrueCowboy426
Re: Tow Hooks
Post by TrueCowboy426 » Sun Jan 27, 2013 9:50 am
tat6272 wrote:I wish there was a definitive number. I was trying to pull a log up out of a creek at my buddies farm when I heard a nasty metal POP. Now the one side of my bumper on he side I was hooked up to appears to be hanging lower than the other side. The plastic wheel well liner was popped out of place too, like the bumper had pulled away from the truck a bit.
Just loosen off the bolts that hold the bumper to the frame and realign your bumper. I've had to do that a few times with all my rams if I got a little over exuberant pulling from the front, especially when your trying to pull up. There is slotted adjustment on those bolts and they will slide if you pull hard enough on the hooks. Good news is I have never broke one, and I've never heard of anyone breaking one. On the PW I had my winch line doubled (~20000lbs pull) to get me out of a hole and with the winch fully stalled I still couldn't get out (ended up having to dig out a bit first), and the tow hook never let go. I feel very safe with the them up to that limit.
tat6272
Re: Tow Hooks
Post by tat6272 » Sun Jan 27, 2013 9:56 am
Very informative. Much appreciated.
Chiprat1
Re: Tow Hooks
Post by Chiprat1 » Sun Jan 27, 2013 4:34 pm
for every Action there is an equal reaction..... ;)
2006 Power Wagon
5th Wheel hitch
:winchmob:
verdesardog
Re: Tow Hooks
Post by verdesardog » Sun Jan 27, 2013 5:21 pm
With your winch line doubled and one leg connected to your tow hook there was only the pull of your winch on the tow hook, the doubled load is only felt on whatever you had the snatch block anchored to. The total load on the truck would be half on the winch leg and the other half on the truck anchor point (tow hook) leg.
I have heard of tow truck companies telling thier drivers not to hook to Dodge tow hooks because of failures. (But those falures could have just been 1500's)
TrueCowboy426
Re: Tow Hooks
Post by TrueCowboy426 » Sun Jan 27, 2013 7:39 pm
Sorry, I guess that was a little misleading. By doubled that's with 2 snatch blocks. One at my anchor tree, one at the truck, and the hook back at the tree. I don't think of 1 snatch block as doubled, but I guess it would be. I certainly don't mean to prove that these hooks should be put under that much strain, just that I personally trust them up to that point, however under no time was anyone near the front of the truck. Under that much load I didn't know what would let go first, thankfully nothing ever did. If someone has a better location to anchor to on these trucks I'm certainly all ears.
Re: Tow Hooks
Post by TwinStick » Sun Jan 27, 2013 8:13 pm
Yes, many Dodge tow hooks have failed. Only one that i know of on a PW. The problem lies here: it is designed for straight on pulls ONLY. If you pull/lift up on it, down on it or at any angle, failure can occur. I am sure it is cheaper to replace a tow hook than it is to straighten the end/s of your frame. Personally, i'm good with that. ;)
verdesardog
Re: Tow Hooks
Post by verdesardog » Sun Jan 27, 2013 10:51 pm
TrueCowboy426 wrote:Sorry, I guess that was a little misleading. By doubled that's with 2 snatch blocks. One at my anchor tree, one at the truck, and the hook back at the tree. I don't think of 1 snatch block as doubled, but I guess it would be. I certainly don't mean to prove that these hooks should be put under that much strain, just that I personally trust them up to that point, however under no time was anyone near the front of the truck. Under that much load I didn't know what would let go first, thankfully nothing ever did. If someone has a better location to anchor to on these trucks I'm certainly all ears.
Ok what you had then was a 3:1 , in that configuration you would have had 1/3 tension on your winch leg and 1/3 on each tow hook leg meaning 2/3 tension on the tow hook. So even thought you had less tension on each leg you had more tension on your tow hook.
tat6272
Re: Tow Hooks
Post by tat6272 » Tue Jan 29, 2013 3:19 pm
Ok, I guess the real question is, what the hell is the purpose of "tow hooks" if they are rated for 5000 pounds ( not stated in any manual-only says for emergency use only), yet the truck weighs way more than that, especially if stuck? And if the winch is rated for 12,000 pounds and is supposed to be doubled back to connect to said tow hook, I would assume that they are capable of withstanding more than 5000 pounds. It does mention in the manual that they should NOT be used by a tow truck to hook to or for towing on roads. So, if the trucks gross weight if around 8500 pounds (more when stuck) how could the hooks only be rated for 5000 pounds? Call me confused. I just assume all of this stuff should be tested and approved.
PWRider
Re: Tow Hooks
Post by PWRider » Tue Jan 29, 2013 6:23 pm
I don't see where 5000lb comes from. Manual clearly shows using hook for doubling winch pull hence at least 12000lb load. Not using for towing IMHO is more liability issue than anything.
Re: Tow Hooks
Post by TwinStick » Tue Jan 29, 2013 9:55 pm
Yeah, i don't think that is the actual rating, maybe it is a "lets be safe for liability lawsuits" rating. I had all 4 of my trucks tires off the ground during one winching session. Rear of truck was strapped to a tree. Front of truck had a 3/8" grade 70 chain to each towhook, & a snatchblock on the tree stump side. Clevis's were used on each towhook, the chain around tree stump, the rear hitch & the tree saver strap in the rear. At that time, i used every piece of recovery gear i had.
verdesardog
Re: Tow Hooks
Post by verdesardog » Tue Jan 29, 2013 10:51 pm
PWRider wrote:I don't see where 5000lb comes from. Manual clearly shows using hook for doubling winch pull hence at least 12000lb load. Not using for towing IMHO is more liability issue than anything.
When winching with a snatch block in a 2:1 (doubled line) configuration there is only half the load on the tow hook and the other half on the winch....The full load is only on the snatch block and snatch block anchor rigging.
VA_Wagon Man
Re: Tow Hooks
Post by VA_Wagon Man » Tue Jan 29, 2013 10:59 pm
Half of the capacity of our winch is 7,500. Dodge has it labeled as12,000. However, 12,000 lb warn winches don't come with a 315:1 gear ratio like our PW has and a 7/16" cable...... The 12,000lb comes with a 261:1 ratio and a 3/8 cable.
Long Gone:
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run
PWRider
Re: Tow Hooks
Post by PWRider » Wed Jan 30, 2013 2:16 am
Half capacity is just that half capacity. I you are totally stuck winch will pull with max force it can. If it is as most believe 15000 lb then other end of the rope will receive equal amount of force. Physics 101: you can't push the rope, for every action there equal and opposite reaction. 30k lb pull on a tree hence the truck will split in half between tow hook and winch. If you use two blocks (one on the hook) then tow hook will be subject to 30k while winch will always be at 15K. Of course the tree (as well as truck on the other end) will get full blown 45k lb. Etc. One can use 15 blocks if so desired. Resulting total pull pull will always be multiple of winch pull times number of strands of rope between anchor and the load.
verdesardog
Re: Tow Hooks
Post by verdesardog » Wed Jan 30, 2013 10:54 am
PWRider wrote:Half capacity is just that half capacity. I you are totally stuck winch will pull with max force it can. If it is as most believe 15000 lb then other end of the rope will receive equal amount of force. Physics 101: you can't push the rope, for every action there equal and opposite reaction. 30k lb pull on a tree hence the truck will split in half between tow hook and winch. If you use two blocks (one on the hook) then tow hook will be subject to 30k while winch will always be at 15K. Of course the tree (as well as truck on the other end) will get full blown 45k lb. Etc. One can use 15 blocks if so desired. Resulting total pull pull will always be multiple of winch pull times number of strands of rope between anchor and the load.
UH,, my bad you are correct with a 2:1 the line connected to the truck has the same load as the winch....
AceMan
Site Admin
Site Admin
Re: Tow Hooks
Post by AceMan » Wed Jan 30, 2013 10:40 pm
Very educational discussion. :D
VA_Wagon Man
Re: Tow Hooks
Post by VA_Wagon Man » Thu Jan 31, 2013 9:44 pm
AceMan wrote:Very educational discussion. :D
Yup, what he said ^
Long Gone:
