Steering box
w2dodge
Steering box
Post by w2dodge » Wed Oct 06, 2021 9:41 pm
Doing a overhaul on my front end....have factory steering box....i would like to change...05154349ab mopar item...will this box work?...found one for 350$...going to use EMF steering set up also....any suggestion on steering box...?..or should I purchase this ...?...
Re: Steering box
Post by RustyPW » Sat Oct 09, 2021 9:08 pm
I'm using a PSC steering box. It's the same as the 6 bolt top cover of the newer 3G boxes. It's been in the truck since 2009. When I broke the oem box in Moab.
w2dodge
Re: Steering box
Post by w2dodge » Sun Oct 10, 2021 5:36 pm
Rusty would you know if a box from an 2012 or newer 6 bolt...work ?..yes pitman arm has to be change . But is there any differences from a Mopar upgrade box and 2012 and newer?
Re: Steering box
Post by RustyPW » Sun Oct 10, 2021 8:18 pm
If I remember right. Someone did the swap, think they had to drill out the bolt holes bigger. Don't really sure.
w2dodge
Re: Steering box
Post by w2dodge » Mon Oct 11, 2021 11:34 am
Geez....ain't doing that....Rusty hows PSC holding up?..
Re: Steering box
Post by RustyPW » Mon Oct 11, 2021 11:27 pm
It's been doing great. Never had any issues with it.
w2dodge
Re: Steering box
Post by w2dodge » Tue Oct 12, 2021 8:24 am
Sounds good.. thankyou
Re: Steering box
Post by RustyPW » Tue Oct 12, 2021 10:52 pm
I have 4 trips to Moab and 10 trips to Rausch Creek with the PSC box. :rockon:
