Battery time
Battery time
Post by Bill2014 » Sun Jan 24, 2021 7:58 pm
The OEM original battery just barely turned over and started the truck this morning at 5 below zero. The 7 year old battery never failed me, but I'm not going to push my luck any longer. I've only used the inexpensive Walmart Everstart in everything I own and always get 6 to 10 years out of them.
:cheers:
:cheers:
$150 and a half hour later it cranks right up!
EasyDoesIt
Re: Battery time
Post by EasyDoesIt » Mon Jan 25, 2021 11:04 am
I'll be honest, I usually like to upgrade the battery but my stock battery in my 2018 wagon is still going strong after 3 years and 50k miles.
In the Las Vegas desert I usually only get 2 years out of batteries.
When it fails, I'm going to replace it with the exact same battery.
Re: Battery time
Post by FordyceCreekTrail » Mon Jan 25, 2021 7:08 pm
These stock batteries are amazing. Other vehicles I have had barely got 1.5-2 years out of the shitty stock batteries.
Re: Battery time
Post by Bill2014 » Tue Jan 26, 2021 12:30 pm
Yeah - I'm keeping the Stock Mopar battery in my garage for now - it never failed to start the truck!
:rockon:
Re: Battery time
Post by Mule007 » Tue Jan 26, 2021 5:02 pm
Don’t let it set directly on concrete, put it on some wood sleepers or will sap any battery PDQ, learned the hard way ☹️
Re: Battery time
Post by Bill2014 » Wed Jan 27, 2021 11:00 am
I just set the old battery there to take the picture for posting... I keep it on a sheet of plywood although I don't think that is required anymore.
Modern batteries are allegedly no longer susceptible to "moisture damage"...
See this nice article addressing this issue.
https://northeastbattery.com/do-cement- ... batteries/
Re: Battery time
Post by FordyceCreekTrail » Wed Jan 27, 2021 12:58 pm
:rockon:
On my 2005 Nissan Titan it leaked and melted everything on the fender well, dissolved the positive battery connector and left me stranded at a concert at 2:00AM. Truck was less then 2 years old I believe. Toyotas go fast as well.
Re: Battery time
Post by Mule007 » Wed Jan 27, 2021 8:31 pm
Bill: thanks for the article, good info ! 👍
