Bad TRE
Posted: Tue Jan 08, 2013 7:12 pm
by John's_05PW
I recently started having a popping sound from the front end when turning the steering wheel. Took it to the shop and they told me that most of my TRE were bad or going bad. They game me a reasonable price to fix it with Moog parts but wanted to know what parts you all would use if you were replacing most of your TRE's.
Re: Bad TRE
Posted: Tue Jan 08, 2013 7:20 pm
by TwinStick
I had all mine replaced with MOOG HD Tie Rods & ends. They are now all greaseable. I have the old Y-style steering. So far, i like em, no issues. I believe there are 2 different lines though: Reg & HD, get the HD ones.
Re: Bad TRE
Posted: Tue Jan 08, 2013 10:24 pm
by John's_05PW
By any chance do you still have part numbers for those or are they the same as the 2500's?
Re: Bad TRE
Posted: Wed Jan 09, 2013 5:10 pm
by TwinStick
No, i do not have the part #'s. They are the same as a reg 2500. I had a shop do mine. Sorry. :cheers:
Re: Bad TRE
Posted: Wed Jan 09, 2013 10:49 pm
by djgaston
I know one of them is ES800532. If you need help finding the others, let me know. I can look them up on Oreilly's site. I just happened to have one of those ES800532s sitting here by me.
Re: Bad TRE
Posted: Mon Jan 14, 2013 2:15 am
by John's_05PW
Did some of our trucks have the T-style steering instead of Y-style from the factory?
Re: Bad TRE
Posted: Mon Jan 14, 2013 2:35 am
by djgaston
T style is the 08.5 and up setup, which is stock on those trucks. The earlier models 03-08 have Y steering. This was a 2nd gen thing too, in case anybody cares. 94-97 had Y steering, and in 98 they introduced a T style setup. Then it went away in 99 and back to Y. Don't ask me "Y" because I have no idea but that's the history of it all. :-)
Re: Bad TRE
Posted: Mon Jan 14, 2013 4:50 am
by John's_05PW
The T-style system uses a straight tie rod to connect the steering knuckles and Y-link design connects the knuckles through two separate bars, correct? So if my 05 has the T-style then its safe to say a previous owner at some point did the swap and for parts I need to look at the 08.5 set-up?
Re: Bad TRE
Posted: Mon Jan 14, 2013 10:18 am
by VA_Wagon Man
John's_05PW wrote:The T-style system uses a straight tie rod to connect the steering knuckles and Y-link design connects the knuckles through two separate bars, correct? So if my 05 has the T-style then its safe to say a previous owner at some point did the swap and for parts I need to look at the 08.5 set-up?
That is correct. My 05 has the T style, i swapped it several years ago.
