After 94k (from 26k to 94k with 37s), looks like it's time for a new wheel bearing front driver side. Can someone indicate the size of the front axle nut so I can make sure I have the right socket before pulling the anvil tires off ?
On a side note, to get the bearing out, does the turn the wheel with one of the bolts backed out and a socket, extension etc. wedged between the knuckle and bearing work to push the bearing out of the knuckle? I did this on my old 97 2500.
