Rough Country Dual Stabilizer Kit
Posted: Mon Oct 05, 2020 2:58 pm
by Mountie
Hey everyone. I just bought this kit and it says you have to have a minimum of 2.5 inches of lift to use it. Aside from the obvious has anyone tried it with the factory lift. it"s a half inch short of required amount. I was thinking of buying a 1.5 inch levelling kit as well if I need it. Just wondering. Thanks.
Re: Rough Country Dual Stabilizer Kit
Posted: Mon Oct 05, 2020 3:52 pm
by ScubaSteve
Mountie wrote: ↑Mon Oct 05, 2020 2:58 pm
You'd be miles ahead to return that and get a Thuren or Carli spec unit if the OEM damper isn't doing it for you. Rough Country products are pretty cheap for the most part, and there is no reason to have 2 steering dampers.
Also, if it says that it requires a minimum amount of lift to fit despite the location of the steering damper and tie rod being absolutely unaffected by lift height, I would say that there's some stupid design flaw involved. Kit is cheap and appears to use some generic off-the-shelf dampers, as well. Will likely have rusted shafts after few rain storms or a winter.
https://www.thurenfabrication.com/produ ... ing-3.html
Posted: Mon Oct 05, 2020 4:36 pm
by SeppW
The OEM unit is pretty good in its own right. If you go with a Thuren kit you can add on a King stabilizer. Are you having issues that would require a dual stabilizer? I can't comment on RC today, but I ran their shocks and stabilizer on a Ramcharger back the early 80s and they may have been the cat's meow then. Today, it's not clear.
I went with Thuren and a King stabilizer, but did go to hydra-assist later. It has advantages in off road situations.
Posted: Mon Oct 05, 2020 5:13 pm
by KevinABQ
Thuren’s article on the issue with a lot of stabilizer kits is worth reading. Oil froth doesn’t work well, and that is what you get when you lay most shocks on their side. The OEM isn’t bad, so of you are going to change to a 3rd part you need to be sure it won’t be worse.
Posted: Mon Oct 05, 2020 9:29 pm
by ScubaSteve
Dual steering stabilizers have always reminded me of the 80's and 90's when people where putting on as many cheap shocks as humanly possible, making their trucks ride even more like a brick. Not trying to trash talk, but honestly, this setup is a step backwards.
Posted: Tue Oct 06, 2020 12:59 pm
by Mountie
Thanks everyone for the quick replies. I will check out Thuren and Carli. I recently saw a Youtube video of a new Powerwagon outfitted with Carli equipment. Looked pretty impressive. The reason I'm upgrading from a single is my stabilizer shock is leaking so I have to replace it. I've had duals before with good results so I'm going that route again. Thanks again.
