09+ steering junk
Posted: Thu Sep 10, 2020 7:39 pm
by ACL123
I bought the mopar steering upgrade 3 months ago and my mechanic says it bad already. He said the tie rod end on the drag link opposite of the pitman arm is bad. I got under there and checked and can kinda turn the drag link a little . Should there be any movement there?
Re: 09+ steering junk
Posted: Thu Sep 10, 2020 7:42 pm
by ACL123
Rockauto says they won't warranty it because it isn't for my truck ( 05) which is bullshit. The dealer wants $150 just to verify it faulty even though my shop says it was. This mopar warranty is a joke.
Posted: Thu Sep 10, 2020 9:33 pm
You went from the Y style to the new T style linkage. Did you use OEM parts, or parts from Rock Auto?
Posted: Fri Sep 11, 2020 8:06 am
by ACL123
Yes. All OE Mopar parts from rock auto.
Posted: Fri Sep 11, 2020 1:14 pm
by ScubaSteve
Yes, if you grab a hold of it you can turn it. It should be tight, but not impossible to move. Rod ends and such become a problem when they are sloppy and/or loose.
Are you having any issues with the steering or is this something your mechanic pointed out during a general inspection? It's not unheard of to hear shops selling customers snake oil...
Posted: Fri Sep 11, 2020 8:59 pm
by ACL123
Yes I took it in because of a vibration at 60+mph. Thought maybe my new tires weren't balanced properly. He said tires are fine but drivers side ball joints and drag link are bad. I know I need ball joints but I don't believe my brand new steering linkage is bad. Just ordered ball joints so ill start with those.
Posted: Tue Sep 15, 2020 9:49 am
by ScubaSteve
Yeah, if you know the balljoints are bad, start with those. I would be surprised if a brand new linkage would be bad so quickly unless you abused it.
Posted: Thu Oct 08, 2020 7:41 pm
by ACL123
Put new ball joints in and much much better but still getting some vibration in the steering wheel.
