AAM ball joints.
Posted: Sat Aug 29, 2020 8:50 pm
by ACL123
Are these OE for our trucks? Any feedback on them would be appreciated.
Re: AAM ball joints.
Posted: Sat Aug 29, 2020 11:47 pm
I installed the Carli ball joints about 60,000 miles ago. And they are still tight.
Posted: Fri Sep 04, 2020 12:06 am
by coder
I have Dynatrac ball joints in my truck. After about 140k miles I rebuilt them, tops were still tight bottoms were loose. For about $195 you can get the rebuild kit for all four ball joints and do the work without having to remove them from the axle, very pleased with this product.
Posted: Fri Sep 04, 2020 4:54 pm
by Oilbrnr
Where do EMF balljoints fall on the good, better, best rating of possible replacements?
Posted: Fri Sep 04, 2020 10:01 pm
by SeppW
ACL123 wrote: ↑Sat Aug 29, 2020 8:50 pm
Unknown.
Posted: Wed Sep 09, 2020 8:54 pm
by ACL123
Out of stock everywhere. May have to goo Moog.
Posted: Wed Sep 09, 2020 10:44 pm
ACL123 wrote: ↑Wed Sep 09, 2020 8:54 pm
If they are splined. Stay away from them.
Posted: Thu Oct 08, 2020 7:32 pm
by ACL123
Posted: Thu Oct 08, 2020 7:34 pm
by ACL123
Tried all weekend to get the hubs off with no luck. Took it to a local shop and it took them 3 days to get the hubs off. Them suckers were on there. Also put 2 new skf hubs on.
Posted: Thu Oct 08, 2020 8:56 pm
When I replaced my ball joints. I had to use a 7" fiber cut off wheel and cut the studs on the ball joints because I couldn't remove the unit bearings. Once I got the steering knuckle out and on the ground. i used a sledge hammer to knock the unit bearings out.
Posted: Fri Oct 09, 2020 9:53 am
by jj141979
Are these factory ball joints?? $69 per side seems pretty cheap!
Posted: Sat Oct 17, 2020 8:40 pm
by ACL123
jj141979 wrote: ↑Fri Oct 09, 2020 9:53 am
Not sure if our trucks come with these but its the same company who makes our axles.
Posted: Sat Oct 17, 2020 9:57 pm
Why would you replace junk with the same junk?
