fuel sensor
Posted: Sun Jul 19, 2020 10:39 pm
by w2dodge
Any one tackle a faulty sending unit?...Fuel gauge in the cluster works fine when tested...(hold down mileage reset..while turning on an off 3 times with ignition key)..I'm hoping I dont have to drop the gas tank...
Re: fuel sensor
Posted: Tue Jul 21, 2020 11:57 am
by cb1987
if its about the same procedure as a dakota then lifting the bed may be far easier. i did a dokata myself by lifting bed about 8in off the frame rails. was fairly easy job actually.
Re: fuel sensor
Posted: Tue Jul 21, 2020 1:17 pm
by Mule
Yup. My usual shop unbolts the bed and slides it over a bit to get to the pump.
Other shops will drop the fuel tank out of the truck to replace the truck.
Shitty shops will wreck the fuel tank in the process.
Re: fuel sensor
Posted: Tue Jul 21, 2020 8:04 pm
by w2dodge
yep I figured that....pump works ..and i have less than a half tank.. most likely doing this alone...just might waste the gas idling every day ...and drop the tank
Re: fuel sensor
Posted: Thu Jul 23, 2020 9:22 am
by jj141979
Slide the bed back... 6 bolts... need at least 3 strong dudes or chicks... pump is right behind the cab... took me about 1.5hrs to do fairly easy
Re: fuel sensor
Posted: Mon Jul 27, 2020 12:57 am
by Colibri
Absolutely move the bed rather than drop the tank
Re: fuel sensor
Posted: Fri Aug 21, 2020 6:53 pm
by w2dodge
getting there
Re: fuel sensor
Posted: Sat Aug 22, 2020 11:26 am
by w2dodge
heres some progress
Re: fuel sensor
Posted: Sat Aug 22, 2020 6:57 pm
by w2dodge
all done... 1 of many things I gotta do...had shoulder surgery and a total hip replacement in the past year and half.. .
Re: fuel sensor
Posted: Sat Aug 22, 2020 9:44 pm
Did it fix the problem?
Re: fuel sensor
Posted: Sun Aug 23, 2020 2:37 pm
by w2dodge
yes it did....thank god
