Page 1 of 2
100% cure for death wobble
Posted: Tue Feb 25, 2020 9:38 pm
by ACL123
Must use a OEM steering stabilizer
Re: 100% cure for death wobble
Posted: Tue Feb 25, 2020 9:45 pm
by ACL123
Although I figured this out about 10 years ago... I figured I would share. Like many of you I was throwing parts at the problem. Finally broke down and took it to the dealership. The mechanic came back after 10 mins and said it was the steering stabilizer. I proceeded to argue with him that I just put a brand new bilstein stabilizer on. He was very adamant that it was the stabilizer. So I said ok. Sure enough it worked. 10 years later and not a whiff of death wobble.
Posted: Tue Feb 25, 2020 10:06 pm
by DamageWagon
Death wobble is developed from the axle being unable to correct tire direction, or from over correction. Death wobble comes from an issue with alignment-affecting components. Tie rod, ball joints, axle straightness, wheel bearings, tires, control arm bushings, and alignment angles.
The steering damper aids alignment components by preventing over correction and by lessening external inputs. The OEM damper is surprisingly good and I only recommend the OEM damper or the Thuren tunes King damper.
The damper can stop death wobble from happening, but the damper itself is not the cure. Neither is caster alone as I hear frequently said. Every alignment components plays a part, and any one of these listed parts can cause death wobble if worn out or not set correctly.
Posted: Wed Feb 26, 2020 12:08 am
by olyelr
I have always been a believer that a steering damper does have its purpose, but curing death wobble is not one of them...but they can often mask it, however.
Well, I guess if they can mask/stop it, then its a win win regardless LOL.
Posted: Wed Feb 26, 2020 12:15 am
by DamageWagon
My OEM damper with a bent shaft, puking oil, with two massive dents in it, kept DW away while I drove 60 miles to a buddy to press in new ball joints. Truck had tires coming off the ground going 40 on the road from DW without the damper.
Posted: Wed Feb 26, 2020 12:51 am
by RustyPW
I had the same issues years ago. Throw a ton of money at it. Pin pointed it to the steering stabilizer. Had a discussion about it on here. Most guys here didn't want to hear about the stabilizer. :roll: Said it was something else. :roll: Pissed me off to no end.
Posted: Thu Feb 27, 2020 1:00 pm
by olyelr
Are you over it yet? :rofl:
Posted: Thu Feb 27, 2020 5:23 pm
by RustyPW
Posted: Fri Feb 28, 2020 12:51 am
by OffroadTreks
ALL THE STABILIZERS!!!!
STABILIZE ALL THE THINGS!!!
Posted: Fri Feb 28, 2020 3:28 am
by KevinABQ
Thuren's note on this is is interesting "There are a lot of trusted brands out there producing steering dampers, but they are often very lacking, in actual effectiveness."
Posted: Fri Feb 28, 2020 12:26 pm
by DamageWagon
The most important jobs of a steering stabilizer are to damp the smallest initial movements, and to output a lot of force at a very low shaft speed to resist big jerks to the steering. Emulsion shocks like almost every Rancho, Bilstein, Fox, etc. do poor jobs of these because the mixed nitrogen in the oil can flow easily through the valves. There’s a lot to be said for a high quality IFP shock in that job.
Posted: Fri Feb 28, 2020 3:19 pm
by Reloaderguy
There's a better way.
Posted: Fri Feb 28, 2020 3:29 pm
by flattire
What are we looking at here?
Posted: Fri Feb 28, 2020 4:07 pm
by RustyPW
I know for a fact that Rancho takes a regular shock and lays it on it's side to use as a stabilizer. Because of this, the valve is not fully in the fluid. This creates dead spots in the travel. Had a nice long ass chewing session with them a few years back.
Posted: Fri Feb 28, 2020 6:50 pm
by olyelr
Reloaders is hydro assist.
Posted: Fri Feb 28, 2020 6:51 pm
by olyelr
Well you done told them! :lol:
Posted: Fri Feb 28, 2020 11:56 pm
by RustyPW
Felt like TwinSticks on the phone. :angry:
Posted: Sun Mar 01, 2020 1:19 am
by olyelr
Bahahahahahahaha
Posted: Sun Mar 01, 2020 7:02 am
by MoparFanatic21
I would like to see better pics of that hydro assist
Posted: Sun Mar 01, 2020 7:48 am
by Bill2014
Twinstick did set the standard for giving vendors feedback - but I suspect he was most effective in person. :excited:
Ah - the ole days...
Posted: Sun Mar 01, 2020 11:25 am
by OffroadTreks
phpBB [video]
Clickable link for Tapatalk
Posted: Sun Mar 01, 2020 4:10 pm
by Reloaderguy
Who engineered that tie rod mount for the Synergy bar?
Posted: Sun Mar 01, 2020 5:36 pm
by DamageWagon
Reloaderguy wrote:Who engineered that tie rod mount for the Synergy bar?
It is from PSC
Posted: Sun Mar 01, 2020 9:57 pm
by RustyPW
Kind of miss that saw off runt. :lol: He was always good for a good rant. :rofl: Wonder how he is doing with his cheby?
Posted: Sun Mar 01, 2020 11:29 pm
by Reloaderguy
It is from PSC
Is that it's intended use? I don't see it surviving Moab on the end of a hydraulic ram.
