New truck, new nanny to hate.
Posted: Tue Jul 23, 2019 8:11 am
by waldo
Autopark. One cheap chineseium door switch away from an immobile truck.
It may or may not be disabled in 4lo, I haven't checked yet.
This post is brought to you by the resident curmudgeon. :poke:
Re: New truck, new nanny to hate.
Posted: Tue Jul 23, 2019 8:21 am
by pdavey
Waldo, so glad I found you.... Sorry had to do it.
Yes autopark is annoying however I have fixed that problem by buckling the seatbelt.
It is a seatbelt sensor not a door sensor and buckling the belt will make it so you can drive with the door open.
Also from what I understand the Tazer DT and Tazer Ram can disable this "feature". I am not near my truck right now but can confirm that later.
Posted: Tue Jul 23, 2019 9:06 am
by waldo
Door ajar will do it too. My understanding is that they implemented it because retards grabbed the radio knob and turned it instead of that stupid rotary knob and jumped out of the vehicle. Combine bad design, idiots and lawyers and you end up with Idiocracy. It wasn't a movie, it was a documentary.
I'll check out the Tazers. Do they require tearing the dash apart to bypass the security module?
It is disabled in 4 lo. It would suck to have to drive that way to get to civilization.
Posted: Tue Jul 23, 2019 9:24 am
by pdavey
I think door ajar does it at a certain MPH when the belt is buckled. I drove up my driveway with the door open to test it.
So the answer to that is maybe. The Tazer Ram I had to tear the dash apart (see my other post on here) however according to Zautomotive they now have a bypass plug that will give you access to both a restricted and unrestricted OBD II port to make it easier.
Email them before ordering.
Posted: Tue Jul 23, 2019 2:42 pm
by KevinABQ
I have one of those bypass cables. It sucks. There are no directions and it implies you should connect it to two different jumper blocks, one of which doesn’t exist in a 2018 power wagon. Complexly worthless. Just throw a couple of $20s out the window, it’s a lot less frustrating.
Posted: Wed Jul 24, 2019 12:50 am
by Punishher7
Is this new with the 2019 and 8spd? I’ve moved my 2018 around with the door open without issue...
Posted: Wed Jul 24, 2019 6:34 am
by waldo
Yeah. You're safe from it if you have a column shifter. I think the 1500s have had it for a while and they flash the ones that don't when they get serviced.
Posted: Wed Jul 24, 2019 8:17 am
by Punishher7
Ahh, good to know thanks. Just another reason to hold on to my “old beater” I guess...
Posted: Wed Jul 24, 2019 1:17 pm
by OffroadTreks
It's actually the result of the class action law-suit about that famous movie star kid from the JJ Star Trek movies, his 8-Speed Jeep Grand Cherokee killed him because it wasn't in park when he got out. Part of the lawsuit demanded that this feature be implemented in all new vehicles. It's not just FCA's either.
So you are right about stupid people.
My Jeep has this, but the funny thing is, it's completely disabled when the doors are off. You just get a warning when your seat belt is unconnected, but you are in the seat that the vehicle is not in park.
So, they must imply a similar sensor to the sensor that turns off airbags in the passenger seat if something lighter than 40lbs is over there.
Posted: Wed Jul 24, 2019 8:57 pm
by Reloaderguy
<3rd Gen Owner> I can drive my truck on the freeway with the doors open! Technologees R bAd!
Posted: Tue Jul 30, 2019 9:26 am
by jsims006
I got mine from securitymodulebypass .com site. All plugs are connected and it was so easy to install on my 2018. Not sure what you are talking about but mine came with instructions. Even without instructions its pretty simple to figure out.
Posted: Tue Jul 30, 2019 2:11 pm
by KevinABQ
The zautomative Ram 2500 cable is what I have iirc. It is terrible. Their bypass electronics alone are fine, just a pain to install. But their special ram cable sucks.
Posted: Tue Jul 30, 2019 9:26 pm
by RustyPW
YEP! :rockon: No nasty nannies. :rofl: If you need nannies. You shouldn't be driving....................let alone breathing. :rofl:
