4wd shifter moves back when accelerating
I noticed today on a moderate acceleration my 4wd shifter moved back like 1 or 2 inches. I tested it out and it did it repeatedly. It’s not shifting out of 2wd but the movement seemed significant. I’ve never noticed this before on this truck (2018 with 9k miles), my previous power wagon, or my TJ. Just seemed weird to me that there’s so much movement on acceleration and while braking as well. I checked the linkage and everything seems tight. Anyone ever noticed this on theirs? Is this normal?
Re: 4wd shifter moves back when accelerating
Normal on 95% of all 4wds... Motor mounts and transmission mounts have that much compounded movement.
Does it on my 2015 as well. I've had zero issues, other than the occasional recall (of which we get plenty) so I assume it is normal.
Does it on my 2005 and 2019. Nothing to worry about.
Only time to worry is when it moves with no resistance. Then it is time to replace the shift linkage
Performance Mods:
Performance Mods:
X2
Preview
AEM Brute Force intake
Gibson CAT back exhaust
Super Chips Flashpac Tuner
Wet Okole seat covers
Line-X bed coating
Trac Rac Sliding Lumber Rack
H2 rims
Line-X bed coating
H2 rims
My 16 does this as well.
- Oilbrnr
Well actually the mounts for the transmission/TC and probably also the motor mounts. It all move together with the torque and is perfectly normal.
'16 with '17 FWC
- Oilbrnr
Well actually the mounts for the transmission/TC and probably also the motor mounts. It all moves together with the torque and is perfectly normal.
'16 with '17 FWC
He was talking about the common problem of the rubber bushing on the TC shift arm giving up and dropping the linkage out of the truck. But otherwise, normal movement. You just never looked down!Oilbrnr wrote:Well actually the mounts for the transmission/TC and probably also the motor mounts. It all moves together with the torque and is perfectly normal.
I generally do my best driving with my eyes on the road haha
Thanks for the replies guys!
Torque imparted on driveline from engine. Mine does it too.
