Trans cooler bypass valve delete?
Posted: Fri Jun 07, 2019 5:40 pm
by waldo
Anyone running a delete for these?
I guess mine stuck yesterday. Local dealer says the OEM part is back ordered.
This block acts like a thermostat for trans fluid. Sends the fluid back to the trans when cold, bypassing the cooler. When it sticks closed, the truck pretty much has no trans cooler. :angry:
It's working correctly right now, but I have a 300 mile drive back home to make next week.
Google search lead me to these .
https://www.thoroughbreddiesel.com/3100052392/
BTW, the OEM # is 68186711AB
ETA, pic is the OEM unit on my truck, just in case any of you want to know what it looks like and where it is. Passenger side next to the engine oil pan.
Re: Trans cooler bypass valve delete?
Posted: Sat Jun 08, 2019 1:55 am
by Colibri
Rodeoflyer had the same problem not long ago, I believe he installed the delete and is happy with the results. Hopefully he sees this and can elaborate. Unless you live next door to low sky I cannot foresee a problem
Posted: Sat Jun 08, 2019 7:53 pm
by Fastnlight
I’m guessing the tranny got hot. Did a warning light come on? How hot did it get?
Posted: Sat Jun 08, 2019 8:32 pm
by KevinABQ
Iirc, you are good way past reasonable temperatures. I think I was told things get bad somewhere above 250?
Posted: Sun Jun 09, 2019 10:55 am
by Rodeoflyer
Yes I installed one and am happy with it. We realized mine was stuck only after the transmission was fully rebuilt. It may have been the root cause of my transmission failure. I was pushing 100k miles and the rebuilt one has a 100k mile warranty so I’m comfortable with it.
It seems like a failure prone design that can take your transmission with it.
Btw, my trans temp shot up to 250 (temporarily during drive home) and a warning light never came on. I was monitoring the temps because of the new trans and just happened to catch it. If not for monitoring the temps on the heads up I would have never known. If I recall the tech said the light may be calibrated for 280 or some crazy hot temp. I’d suggest monitoring temps closely and if it sticks again you can tap on it a little with something to free the stuck checkball. That may get you home safely.
Install vid: https://youtu.be/zp9A3IX288o
Posted: Sun Jun 09, 2019 11:30 am
by Fastnlight
@Rodeo Flyer. Good thing you were monitoring the temps. Amazing there is not a warning light or sound. I tend to monitor my tranny temp when towing but will be much more diligent about it. I’m leaning towards getting this delete but am worried about voiding the factory warranty. Also, the very existence of the factory installed bypass begs the question: What are the positives to warming your tranny up sooner? There has to have been some benefit for Ram to have gone to the trouble of installing these. Hopefully a tranny guy will comment.
Posted: Sun Jun 09, 2019 11:32 am
by Fastnlight
The very fact that Ram has these on backorder is disconcerting. They must be replacing a lot of them.
Posted: Sun Jun 09, 2019 11:36 am
by Rodeoflyer
Well, the ad for the delete says they fail ‘in every case’. I’ll take my chances with the delete. My transmission builder said he was fine with it and it won’t affect his 100k warranty. He was investigating how to modify the stock one to convert it to a bypass when I located this one.
Posted: Sun Jun 09, 2019 12:22 pm
by waldo
Thanks for the link, Rodeoflyer.
I have no idea what temp the light tripped, but when I changed the EVIC it was reading under 200. The light didn't come on until I was a mile from the cabin, so it didn't get driven far like that.
As far as the question as to why they use it. IDK, probably cold climate. In the old days trans fluid ran through a loop in the radiator. That brought it up to temp quickly, but as we all know it doesn't help keep temps down.
It's definitely failure prone and doesn't fail safe (open). The fact that none are available and the deletes even exist says it all.
It seems the KISS principle is lost on the engineers of today. Just because you can do it doesn't mean you should do it.
This thing (at best) will leave you sitting out in BFE with your thumb in your butt waiting for it to cool down, or a smoked trans.
I called Ram customer support, opened a case and bitched about it. They were more concerned about some other BS recalls on my truck and were generally no help.
Posted: Sun Jun 09, 2019 12:27 pm
by Fastnlight
waldo wrote:Thanks for the link, Rodeoflyer.
So your saying a light did come on for you? Appears RodeoFlyer didn’t get a light.
Posted: Sun Jun 09, 2019 12:36 pm
by Rodeoflyer
Sounds about right, however the draglink falling apart and killing an entire family may be priority over their poor transmission programming causing failed transmissions or whatever other issues are reported such as a high rate of thermostat failures.
I had the solenoid recall done along with PCM update and the transmission was shifting so much better, like night and day better (and I hate when people say night and day but it was). I think the less than ideal (and I say that nicely) transmission programming and this faulty thermostat killed my original transmission. Fortunately I had an extended 125k mile warranty through my lienholder and they paid 100% for the rebuild. I paid another $1000 or so for upgraded internals and a billet valve body (required for the 100k mile warranty with the builder).
Posted: Sun Jun 09, 2019 12:44 pm
by waldo
I had the solenoid recall done along with ECM update and the transmission was shifting so much better, like night and day better (and I hate when people say night and day but it was). I think the less than ideal (and I say that nicely) transmission programming and this faulty thermostat killed my original transmission. Fortunately I had an extended 125k mile warranty through my lienholder and they paid 100% for the rebuild. I paid another $1000 or so for upgraded internals and a billet valve body (required for the 100k mile warranty with the builder).
I checked the draglink jam nuts myself. I'm not letting anyone weld on it. What moron came up with that idea? I'll wait until they come up with a real solution.
Posted: Sun Jun 09, 2019 12:59 pm
by Rodeoflyer
Yeah my draglink nuts loosened a few times but I put a stop to that. Haven’t had an issue with them in 50k miles now. I won’t allow them to weld the nuts either. I’ll buy a synergy draglink.
Some other info lace we’re on the trans topic...RFE transmissions have a weak stock valve body. My 4th gear clutch was toast. Worn down to the backplate....
Since its early production in 1999, the RFE platform has been plagued with many issues. Some of the biggest problems have been premature clutch failure and valvebody wear. The premature clutch failure can be isolated to hydraulic cross leaks and warped valve bodies. Approximately 80-90% of those cross leaks have been found in the OE channel plate casting.
For example, fourth gear clutch failure, premature valvebody bores worn, and defective valve lands. So, we decided that the best way to fix this issue was to eliminate channel plate flexing.
Hence, a channel plate made from billet was engineered, also with shallower channels to expedite gear shifts.
Posted: Sun Jun 09, 2019 9:14 pm
by flattire
That replacement part causes cancer according to California.
Posted: Mon Jun 10, 2019 11:44 am
by Bill2014
That's only if you suck on the transmission lines during installation :rofl:
Posted: Mon Jun 10, 2019 11:53 am
by Rodeoflyer
I think my toothpaste now has a disclaimer about causing cancer in CA. I don’t live in CA so I guess I’ll be alright.
Posted: Mon Jun 10, 2019 11:56 am
by ramv
hmm. THis is interesting. My transmission always runs 172 which is pretty ok in my opinion. However, I didn't realize it was a mechanical ball valve and not electronically controlled.
On my old 46RE, it wouldn't shift to OD if the fluid dropped below 100 deg, and it would drop during extended lock up in cold weather after I bypassed the oem thermostat. (So if you downshifted to third on a hill, it wouldn't go back to OD until it could heat up.)
Posted: Mon Jun 10, 2019 3:17 pm
by Colibri
I believe they added the thermostat mostly to help meet more stringent CAFE regulations. Cooler fluid is thicker and more viscous. Getting the transmission to temperature as fast as possible wastes as little fuel as possible.
Posted: Mon Jun 10, 2019 5:22 pm
by Oilbrnr
Interesting. Pricey little chunk of aluminum. (but cheaper than a rebuild)
Posted: Mon Jun 10, 2019 5:41 pm
by Rodeoflyer
I believe you’re right Tim. But then you’re always right :).
Posted: Mon Jun 17, 2019 4:38 pm
by waldo
A little update.
I said in my first post that Ram was of little help. I did get a call from someone there that could get that part to the closest dealer so I could drive home.
Have to give credit where it's due.
Posted: Mon Jun 17, 2019 6:22 pm
by Rodeoflyer
Glad it worked out and you didn’t have to white knuckle it home.
