Page 1 of 3
Front Diff Blow Up
Posted: Mon Nov 26, 2018 6:41 pm
by chrisjameswagner
Driving to work this AM at about 35mph trucks comes to a screeching halt. I try to move forward but no, just binding and noise. Shift to reverse, same thing. Get our of truck to see what up and see about a 15 foot double skid but no glaring issues under the truck. Get back in try again with same result. Shift the transfer case to low, high, neutral, all good. Leave the transfer case in high and try to move forward - no good; backwards enough movement to get me off the road but lots of grinding noises and strained movement. Have flat towed to dealer who says front diff needs to be rebuilt. 79.8K miles. Thoughts on what could cause that? Seems way to early for that to occur.
Re: Front Diff Blow Up
Posted: Mon Nov 26, 2018 10:10 pm
by FordyceCreekTrail
Driving a modern vehicle long enough to even see a diff blow up seems like a stretch. They should go what a million miles. Sounds like a defective unit. Probably was bad from the start, just a little off. I assume it had oil and not water in it however.
Posted: Thu Dec 06, 2018 3:35 pm
by coder
Have you had a front pinion seal leak fixed in the past if it was not done right it could have caused some premature bearing wear?
If you want an alternative to the dealer for repairs J&S Gear Co. is excellent the shops in Huntington Beach.
http://www.jandsgear.com/
Posted: Thu Dec 06, 2018 4:45 pm
Any updates on this?
Posted: Sun Dec 09, 2018 10:44 pm
by chrisjameswagner
Yes, I did have the dealer fix a weap in the past. For those following along, things have progressed for the worse. drained the transfer case to find black liquid... Seems u joints also may be bad. I'm thinking dealer had no idea what caused my initial issue and have guessed their way along. Starting to get expensive and I'm thinking we'll be headed to arbitration over this.
Posted: Mon Dec 10, 2018 5:43 pm
This is sounding like a mess.........
Posted: Mon Dec 10, 2018 6:30 pm
Train wreck.
Posted: Mon Dec 10, 2018 6:53 pm
by chrisjameswagner
Powertrain wreck more like it.
$6400 is the tally.
I've asked Chrysler to get involved and that's been going on its third week now.
None of the parts should have failed. Mild towing, mild offroading, 80K miles, all maintenance done at appropriate intervals.
Unfortunately not knowledgeable enough to know if dealer f'ing me but knowledgeable enough to know they can and will...
and most likely did.
Hoping Chrysler can come through with some relief.
Posted: Mon Dec 10, 2018 10:02 pm
by cb1987
if the dealer had the pinion nut off at some point in time then its completely plausible they pooched the job which is what it kind of sounds like.. even though all they would of needed to do was mark the nut and reinstall it back to original position or a fraction tighter. this is why a dealer will never touch my truck unless the engine blows up
Posted: Tue Dec 11, 2018 10:53 am
by chrisjameswagner
Right and in another 10-20K miles or less, I'll get to see if the f'd it up again...
Posted: Tue Dec 11, 2018 11:06 am
by 13powerwagon
I have had my front pinion seal on my 13 replaced 3 times under warranty. Rear leaked once and they replaced that seal but screwed up the rearend in the process so that got replaced under warrnaty as well. Apparently the dealerships have issues fixing things right the first time so it is not unlikely that they messed up your front dif when they replaced the seal.
Posted: Tue Dec 11, 2018 12:00 pm
by NickTF
It would take a serious leak for me to risk a half ass dealer tech I didn't know doing work like that. Sometimes it's just easier to add some fluid. IN a perfect world no one should be having these problems but in today's auto dealerships you really run a risk of getting very poor service that will ruin the experience of vehicle ownership.
Posted: Tue Dec 11, 2018 9:09 pm
by Ducky's Dad
Last time I asked, the dealer near me had sold exactly one PW in 13 years (not mine). Think their techs know anything about PWs?
Posted: Tue Dec 11, 2018 9:36 pm
by Reloaderguy
There's only one way to properly fix a leaking pinion seal. I suspect Ram doesn't authorize under warranty the proper way. Over tightening the pinion nut can cause the pinion to seize up.
Posted: Tue Dec 11, 2018 9:46 pm
by 13powerwagon
Im sure you are right on with that statement. I dont know about the OP but when I told the service guy mine was leaking he said they would take it back and bang another seal in. They had it all of 20 minutes.
Posted: Tue Dec 11, 2018 10:18 pm
by Reloaderguy
They obviously just zipped off the nut, pried out the pinion seal, put in a new seal, and then retightened the nut. That works sometimes, I've done it before. There's no way to measure the pinion preload doing it that way though. I think a lot of shops tighten the nut and then add some rotation to crush the sleeve some more. Not all sleeves crush uniformly so they may add too much preload and seize up the bearing.
Posted: Tue Dec 11, 2018 10:29 pm
by chrisjameswagner
Appreciate the commentary guys. I can learn something from that. FCA Care is now saying they probably cant cover due to the Carli aftermarket parts (springs, control arms). I am curious if that may have something to do with the situation via premature wear...
I'm seriously thinking its time to sell...
Posted: Tue Dec 11, 2018 10:40 pm
by 13powerwagon
Yeah, I think thats exactly what happened. 3 leaks later they finally put some type of sealant in there with the seal and it has been leak free for 20k but I am sure it will leak again and ill have to have it fixed on my dime this time.
To the OP, that sounds like a bunch of BS, control arms and springs should have no impact on the internals of the front dif. Most likely, as reloaderguy said, they did not fix it right and it caused the issue you are having.
Posted: Tue Dec 11, 2018 11:13 pm
by Low_Sky
chrisjameswagner wrote:Appreciate the commentary guys. I can learn something from that. FCA Care is now saying they probably cant cover due to the Carli aftermarket parts (springs, control arms). I am curious if that may have something to do with the situation via premature wear...
That’s a load of BS, but it’s going to be a fight if they’re trying to play that game.
Posted: Tue Dec 11, 2018 11:25 pm
by Reloaderguy
Have it towed to an axle shop so it can be fixed right. Your dealer is tired of you and is subtly acknowledging they are incapable of remedying their damage and unwilling to make it right. FCA is never going to warranty the repair now that the dealer has turned on you; not stock, not modified, not ever. Do you like your truck? If yes, pay a non dealer to fix it. If no, sell and buy a different brand. I'm sorry but you're now on your own.
Posted: Wed Dec 12, 2018 8:53 am
Differentials are fairly tricky. Even many pros send them out to an expert. Not impossible to build, but like a transmission or engine internals not something you want to get wrong. Pinon seals are a common issue. My Nissan Titan had to have them replaced at 160K and 210K I believe. A lift causing a differential failure is complete BS. Not only is this a heavy duty truck, but explain to me the mechanics of that. Nissan did the same thing to me on an Xterra, drove it up a small hill and bam, the rear diff that was under engineered exploded. By the time we went to Arbitration they were installing diffs with double the spider gears, but insisted my lift was the cause of the failure.
Posted: Wed Dec 12, 2018 11:17 am
by chrisjameswagner
Supposedly the Carli arms "move the front axle 2" forward".
Seems that would change some of the geometry in the diff as the attaching driveline distance is now changed - yes/no?
Posted: Wed Dec 12, 2018 11:59 am
by DamageWagon
chrisjameswagner wrote:Supposedly the Carli arms "move the front axle 2" forward".
On 03-13 trucks the max the front axle can move forward should be 5/8”. Thuren arms move the axle 1/2”. This will have no bearing whatsoever on the issue at hand. If it was the driveshaft wearing out there would be a different discussion involving the condition of the joints, but otherwise no, zero effect on bearing load.
Posted: Wed Dec 12, 2018 12:16 pm
by 13powerwagon
The front drive shaft is able to extend and retract to compensate for the slight forward movement of the front axle. Any time you are towing the front end is in a different position than it is at normal ride height. So if the dealer argument was true, anyone who towed or hauled heavy would have front diff problems as well.
Posted: Wed Dec 12, 2018 12:48 pm
by Bill2014
Hmmmm :o
I agree - the forward movement is not an issue. However, any pinion angle change associated with a lift could add to the bearing stress.
If you had a seal replacement done on the diff - and then it failed - the work was not done correctly... End of story!
