code p0171
Posted: Tue Nov 07, 2017 7:12 pm
by w2dodge
anyone have experience with this code: p0171?..truck runs fine she just turned 100,000m...something about running on the lean side..
Re: code p0171
Posted: Wed Nov 08, 2017 1:47 am
by Retired BLM Rig
The P0171 code means that on the drivers side bank of the engine (bank #1), the fuel system is running weak or a vacuum leak exists. A lean condition occurs when the engine either receives too little fuel or too much air. Since it's lean only on one bank and not both, I would suspect a vacuum leak rather than starving for fuel. Probably a leaking intake manifold gasket, but would need more testing to confirm. Find a shop around you that has a smoke machine for finding vacuum leaks.
Good luck! :patriot:
Re: code p0171
Posted: Wed Nov 08, 2017 1:48 pm
by stooper
also possible aging (lazy) upstream o2 sensor.
Re: code p0171
Posted: Wed Nov 08, 2017 8:48 pm
by w2dodge
picked up the truck from dealer..had airbag recall...no engine light....they found a p1684 code low voltage..rain the day the p0171 code came on while idling in the driveway..going deer hunting this wknd..hope nothing lights up
