Firestone Riderite bags with Daystar cradles
Posted: Wed Oct 25, 2017 7:32 pm
by israelstanage
Installed bags, cradles, and on board air today. Pretty straight forward. I used the lower brackets that came with my bags because that seemed like way less of a headache than threading a custom hole and the brackets are less than 1/2 inch thick. Bags need 5 psi minimum. They rest in cradles at normal ride weight but will separate when rear axle goes full droop. Only custom mod was a slightly longer tapered head bolt going from lower bracket to the day stars. Had to grind a bit of the bolt off, but the bags seat in the tapered part of the cradles and don't ever actually rest on the bottom.
Went with a wireless one compressor with remote.
Re: Firestone Riderite bags with Daystar cradles
Posted: Wed Oct 25, 2017 9:59 pm
Nice!
How do you like that wireless one setup?
Posted: Wed Oct 25, 2017 10:43 pm
by israelstanage
I wouldn't have done bags without it. I often haul heavy bed loads relatively short distances; the inconvenience of locating a compressor or hooking up my portable one would have kept me from using them. It has 3 presets and won't let you deflate any lower than 5 psi. Airing up/down literally at the press of a button. Compressor install is super easy as well.
Posted: Wed Oct 25, 2017 11:13 pm
Well that sounds EXACTLY like what I want for my bag setup. I dont necessarily want/need a wireless remote control for it, but a button in the truck to automatically inflate/deflate would be tits for sure.
Posted: Wed Oct 25, 2017 11:38 pm
by israelstanage
Didn't mean to cause confusion; it is a remote system. But no wires. Tuck it away and only get it out when you need it. It is backlit but my flash is washing it out. Also has a thingy on the back like a garage door opener. Auto sleeps when not in use.
Posted: Thu Oct 26, 2017 5:29 pm
by ramv
Link to the compressor/remote?
Looks slick.
Posted: Thu Oct 26, 2017 5:46 pm
by TJ02Gopher
Posted: Thu Oct 26, 2017 7:26 pm
by israelstanage
That's the one. Boys at 4 wheel parts recommended it. They said they have had quite a but of positive feedback. Also chose the bags I did based on their recs.
Posted: Fri Oct 27, 2017 8:48 pm
by ramv
That is slick. About $300 it looks like. plus bags and cradles....
Posted: Sat Dec 16, 2017 4:42 pm
by ramv
Is the compressor standing up ok in that spot? Just concerned about water.
Posted: Sat Dec 16, 2017 4:46 pm
I believe they are designed to be installed under the truck, exposed to all of the elements of daily driving.
Posted: Sat Dec 16, 2017 11:55 pm
by israelstanage
Still working great. Been through plenty of rain and weekly washes with under carriage blasts. As noted by olyelr, they are designed with exposure in mind.
Posted: Sun Dec 17, 2017 12:19 am
by ramv
cool. Think I might mount mine under the front of the bed, but am considering the same spot you had
Posted: Wed Dec 20, 2017 11:23 pm
by DocPaulo
Nice.. have the same setup and did the same exact things...
