5.7 Hemi Tick
Lazarus
5.7 Hemi Tick
Post by Lazarus » Wed Aug 30, 2017 12:41 pm
My 2005 has developed the infamous Hemi Tick over the past few months and it's driving me crazy. Anybody had this experience and found a fix for it? I'm running synthetic blend 5-20 and my truck has 79k miles on it. Thanks!
Pit Slave
Re: 5.7 Hemi Tick
Post by Pit Slave » Wed Aug 30, 2017 12:49 pm
I run 5-30 in my 2005. Check the passenger exhaust manifold. The studs may have broken off at the rear most part. I had them all replaced on mine plus had the high temp silicone exhaust sealer put in as a gasket sealer a few years ago.
Mule
Re: 5.7 Hemi Tick
Post by Mule » Wed Aug 30, 2017 1:33 pm
Check exhaust studs... i've broken them on both sides. Also have the shop check flatness of the manifolds; mine were warped which is what caused the studs to pop.
Re: 5.7 Hemi Tick
Post by coder » Wed Aug 30, 2017 7:06 pm
Mule wrote:Check exhaust studs...
x2 they rust through over time and break
Lazarus
Re: 5.7 Hemi Tick
Post by Lazarus » Thu Aug 31, 2017 12:04 pm
I'll check that out. It sounds more like lifters/valves to me than an exhaust leak but the exhaust is definitely an easier place to start.
Socalboarder
Re: 5.7 Hemi Tick
Post by Socalboarder » Thu Aug 31, 2017 10:55 pm
Definitely check the exhaust manifold. I had the drivers side done a couple of month ago. Was quiet until the passenger side started about 2-3 weeks ago. Funny thing about warranty work......they knew it was going to happen on the passenger side, but until it makes noise, they wont fix it. I have a $100 deductible on my 100K warranty, so they got me by the Benjamins!
TommyG
Re: 5.7 Hemi Tick
Post by TommyG » Fri Sep 01, 2017 11:47 am
Mine is a 2012 with 60,000 on it and I have had both sides done already.
Lazarus
Re: 5.7 Hemi Tick
Post by Lazarus » Fri Sep 01, 2017 12:10 pm
What manifolds are you guys replacing the originals with?
Re: 5.7 Hemi Tick
Post by coder » Fri Sep 01, 2017 12:41 pm
Lazarus wrote:What manifolds are you guys replacing the originals with?
Studs or the hole manifold? Usually the manifold is fine and does not need to be replaced.
Lazarus
Re: 5.7 Hemi Tick
Post by Lazarus » Sun Oct 01, 2017 9:48 pm
I might replace the whole manifolds. Anyone know of any good after market headers that bolt straight onto the stock exhaust setup?
freemanwalkin
Re: 5.7 Hemi Tick
Post by freemanwalkin » Tue Oct 03, 2017 12:09 am
Wellll. . .? Anyone . . .? I too have the same problem :rofl:
CombatWombat
Re: 5.7 Hemi Tick
Post by CombatWombat » Tue Oct 03, 2017 9:43 am
The old Manifold is better than a new Manifold.
Because it already was hot. When my PW got broken Exhaustmanifold Studs i flattened the Surfaces from the Manifold.
I got it on a flat grinder.
I took the 2 middle flanges 3/10mm deeper than the two outer flanges. So the manifold itself helps the studs ond the back cylinders to hold the Flange tight to the Head.
Did this on Passenger Side and have to do it on Driver Side to...
TommyG
Re: 5.7 Hemi Tick
Post by TommyG » Mon Oct 09, 2017 1:50 pm
I just did studs since it was under warranty. I am going to look at a set of JBA shorty headers if it happens again and it is on my dime.
