Post
by TankerZak » Sun Jul 02, 2017 7:33 pm
Chisel wrote:Congratulations on the new ride. I live in Raleigh as well. Not sure if this qualifies as an upgrade per se but one of the best things I put on my '16 is an AMP bed step. Helps a ton if you're gonna be crawling in and out of the bed much. I'm not a short guy but I got short legs so it was basically a must have.
Ditto on the off-road recovery stuff as well. Need all that first.
I did an AMP bed step which is awesome!!! I also did a Backflip Revolver. Its literally a roll-up hard tonneau. Its the best tonneau I've ever had and i think I'm on number 5 or 6...
I saw again... roll up hard tonneau AND if you have the Ramboxes the mounting system is beautiful. The mounting rails slide right into the cargo management that comes with the Rambox setup!
Let me know if you want pics.
