Thinking underneath the box, winch mount idea????
Posted: Wed Jun 07, 2017 10:02 pm
So.... as per usual, I have to take a simple idea and make it super complicated!
I want to run a super high clearance rear bumper but I also want to run a rear winch and still retain a hitch. Every design I have come up with thus far has ended in pick any two: High clearance, Winch, or Hitch. Winch and high clearance is easy, Hitch and high clearance is easy, Winch and Hitch are easy but hang down low.
So, what about running a mid mounted winch, making a plate mount above the rear frame rails, in the bed, in the unused space below my tool box? Then I can run the cable out through guides above the bed floor, through the tailgate, to a fairlead mounted to the top of a 4"x4" tube RV hitch that would be mounted via Thuren's rear bumper brackets. To facilitate this, I can build a raised bed floor under which I can mount my OBA setup, and my Pelican storage boxes. (basically make a flatbed hidden inside my bed) Of course I will have to cut the tailgate extensively to be able to pass the cable though it and to be able to open it with a fairlead there, that's no big deal though, as my tailgate is destroyed anyway. The only drawback would be my bed floor would be at the same height as the tops of my wheelwells, VERY shallow bed BUT, it would be perfectly flat so that's good I guess!
The other option would be to sink the winch mount below the bed floor so the cable routes under the bed but, I don't know if there is enough clearance between the frame crossmembers and the bed reinforcements to mount guides under the box???
The mounting idea would be similar to many military vehicle mounts, vector mounts, and the Foers Ibex mount. (with the exception that those mounting configurations typically allow for front and rear usage of that mid mount winch vs I would only be using the rear usage portion) From what I have read, as long as the last guide is centered and is a minimum of one meter from the winch drum, the cable should spool on perfectly layered every time, no matter what angle the cable is routed out the fairlead. Mid mount and rear mount (for front use) winch mounts are common on winch trials competition trucks so, I would imagine it must spool nicely!
Thoughts???????
Anybody have any experience with a similar setup????
Can our frames handle the forces from a mid mounted winch running cable out to a rear mounted fairlead????
Thoughts???????
