Air box mods
Posted: Fri Apr 14, 2017 3:24 pm
by Easttnrhino
On the 6.4 is there any mods where it draws through fender or to box itself to help airflow at WOT. Thanks
Re: Air box mods
Posted: Fri Apr 14, 2017 5:38 pm
by Reloaderguy
The factory airbox does draw through the inner fender.
Re: Air box mods
Posted: Fri Apr 14, 2017 7:41 pm
by OffroadTreks
Yea, just gotta cut a hole in your fender.
Re: Air box mods
Posted: Fri Apr 14, 2017 8:30 pm
by nts007
A bigger hole will allow more air flow. Also you can make cardboard wind deflectors to enhance the flow direction using masking tape to hold them in place.
Re: Air box mods
Posted: Fri Apr 14, 2017 11:01 pm
by OffroadTreks
It works really well. Gained like 10HP
Re: Air box mods
by nts007
The proof is in the pudding^^^^^^^
Re: Air box mods
Posted: Sun Apr 16, 2017 11:12 am
by Easttnrhino
Inside of airbox is this to reduce noise?
Re: Air box mods
Posted: Sun Apr 16, 2017 3:11 pm
by Calvinm119
You can also use a 3 in hole saw to cut out an airway at the bottom of the airbox and run airduct hose from the hole to the to the front of the vehicle. You'll need to buy a few things to make it look cosmetically good. I did that on my last truck and it worked pretty good.
Re: Air box mods
Posted: Sun Apr 16, 2017 3:49 pm
by OffroadTreks
My Airbox already had an inlet that ran into the fender on my 2015. Before even adding the AEV intake.
Re: Air box mods
Posted: Sun Apr 16, 2017 10:15 pm
by Rodeoflyer
Easttnrhino wrote:Inside of airbox is this to reduce noise?
More likely for airflow control. Probably a good thing.
Re: Air box mods
Posted: Sun Apr 16, 2017 11:02 pm
by nts007
Or a place to attack a shop vac hose to
