Page 1 of 5
2014-17 tire size consensus
Posted: Sun Feb 26, 2017 12:41 pm
by Kodiak
Hi guys, new member here, been lurking for a while and my account finally got approved. Appreciate all the knowledge on here.
I've been looking for some time now and I still haven't gotten a good sense about what the largest tire size I can fit on the stock wheels without rubbing at full lock or articulation on the 2014-17's. Any consensus on this?
In before "use the search feature"... I have. From 35s to 37s to 295/75's. Read many posts, still don't have a clear idea, was hoping to hear a more consistent message with this thread. Thanks in advance!
Update, making list of tire brands/sizes with fitment experience:
BFG KO2s 35X12.5. No rubbing the arms or swaybar, however, have not yet been in a full articulation situation to test the rubbing while turning.
Nitto Trail Grappler MT's 35x12.5 on factory wheels. No noticeable rubbing on radius arms or sway bar and had it off-road quite a few times with sway bar disconnected and flexed
Nitto Ridge Grapplers 37x12.5 stock wheels, with 1.5" level and 45 psi minor rubbing at full lock, spare location not attempted.
Toyo RT 35x12.50 on stock wheels, fits under bed in stock location, zero rubbing on radius arms on road or off road.
Toyo RT's 37x12.5 on +18mm offset wheels rub the fender liner and base of the inner part of the fender flare. Mild trimming required.
Toyo Open Country AT/II 35x12.50 on stock wheels, fits under bed in stock location aired down, no rubbing on Radius or Sway bar
Yokohamas 315/70-17 no rubbing on road, no noticeable rubbing with light off roading, unknown with sway bar disconnected.
Re: 2014-17 tire size consensus
Posted: Sun Feb 26, 2017 12:56 pm
by Reloaderguy
On stock wheels probably 35x11.5. 35x12.5 and 37x12.5 on stock rims are both going to rub the radius arms and sway bar.
Posted: Sun Feb 26, 2017 7:50 pm
by Kodiak
Reloaderguy wrote:On stock wheels probably 35x11.5. 35x12.5 and 37x12.5 on stock rims are both going to rub the radius arms and sway bar.
Haha thanks buddy for responding. This isn't going well...
Did you ever get your dual alternator add-on done?
Posted: Sun Feb 26, 2017 9:35 pm
by Z's2016PW
I have a 2016 Laramie Power Wagon. Currently running Yokohamas in the 315/70-17 size with the stock wheels. Absolutely no rubbing while on road. Haven't noticed any rubbing off-road, but nothing hard core so far. The sway bar has not been disconnected yet with these tires.
Zane
Posted: Mon Feb 27, 2017 8:27 am
by Kodiak
Z's2016PW wrote:I have a 2016 Laramie Power Wagon. Currently running Yokohamas in the 315/70-17 size with the stock wheels. Absolutely no rubbing while on road. Haven't noticed any rubbing off-road, but nothing hard core so far. The sway bar has not been disconnected yet with these tires.
Zane
Happy with the Yokohamas?
Posted: Mon Feb 27, 2017 9:30 am
by shacke
Replaced my stock tires with 35X12.5 KO2s. The tires have not rubbed the arms or swaybar, however, I have not yet been in a full articulation situation to test the rubbing while turning.
As for the tires themselves, they are absolutely better than the Duratracs by every measure important to me (ride, handling (pavement and gravel), quiet, rain and snow). I cannot compare the KO2s to Duratracs in the mud as I did not have the Duratracs in the mud, only gravel roads.
Posted: Mon Feb 27, 2017 9:31 am
by TankerZak
I have a 2016 Laramie Power Wagon on Toyo RT 35x12.50 on stock rims. No rubbing at all.
by TankerZak
Posted: Mon Feb 27, 2017 10:19 am
by 14PowerWaggy
I had 35x12.5 Nitto Trail Grappler MT's on factory wheels on my 14... Did not have any rubbing on radius arms or sway bar and had it off-road quite a few times... Sway bar discoed and flexed out... If it did rub it was so minimal that I didn't notice... Have 37's with aftermarket wheels on my 15 with no lift and they rub the sway bar and the fender liners... Also had to trim the fender liner and pinch seam to make them work on the stock suspension...
Posted: Mon Feb 27, 2017 10:22 am
by Kodiak
TankerZak wrote:Image
Beautiful truck! Tires look perfect!
Posted: Mon Feb 27, 2017 10:29 am
by Z's2016PW
Zane
I have the Yokohama GO15. They are severe rated and have been very happy with them so far.
Zane
Posted: Mon Feb 27, 2017 10:31 am
by Kodiak
14PowerWaggy wrote:I had 35x12.5 Nitto Trail Grappler MT's on factory wheels on my 14... Did not have any rubbing on radius arms or sway bar and had it off-road quite a few times... Sway bar discoed and flexed out... If it did rub it was so minimal that I didn't notice... Have 37's with aftermarket wheels on my 15 with no lift and they rub the sway bar and the fender liners... Also had to trim the fender liner and pinch seam to make them work on the stock suspension...
Also beautiful. For those running 35s, any trouble mounting in spare tire location? I know another member had to really deflate his Toyos to make it fit.
Posted: Mon Feb 27, 2017 10:34 am
by 14PowerWaggy
I could not get a fairly worn, read use as spare only, 35x12.5 Nitto Trail Grappler MT to fit in the factory spare location... Even deflated to about 10PSI... I know others have said they have successfully fit a 35" spare in the factory location... I, however, was not successful... I also knew I was going to go to 37's anyway so had already talked myself into using the bed for the spare...
Posted: Mon Feb 27, 2017 10:49 am
by OffroadTreks
Toyo Open Country AT/II 35x12.50 on stock wheels, no rubbing on Radius or Sway bar.
Posted: Mon Feb 27, 2017 10:55 am
by Kodiak
MikeKey wrote:Toyo Open Country AT/II 35x12.50 on stock wheels, no rubbing on Radius or Sway bar.
You do quite a bit of off roading, any issues so far? Do they make an "extreme" version in that size for more aggressive looking sidewall?
Posted: Mon Feb 27, 2017 1:03 pm
by OffroadTreks
That size is the Xtreme. [Yea they spell it with an X right on the side wall like it's 1994]
I haven't had issues yet. I've seen guys with 37's have issues with them rubbing the fender liner when stuffed. I haven't really stuffed the tire in awhile.
I think it might of rubbed a little bit on the fender liner. I know that GTOMike's 37's rub the fender liner like crazy when stuffed.
But no real problems. No missing chunks in the tires or anything that would cause concerns. They'll get put through the paces again in Moab in May.
Posted: Mon Feb 27, 2017 1:40 pm
by Kodiak
Awesome, thank you! Happy with the overall performance compared to the duratracs?
Posted: Mon Feb 27, 2017 4:55 pm
by yellowranger1
Another confirmation for the Toyo RT 35/12.50 on stock wheels, fits under bed in stock location (BARELY), zero rubbing on radius arms on road or off road.
Posted: Mon Feb 27, 2017 4:58 pm
by olyelr
Some good info in this thread. I like it that you are adding info to your very first post, Kodiak... that's a great idea!
Posted: Mon Feb 27, 2017 5:38 pm
by Kodiak
olyelr wrote:Some good info in this thread. I like it that you are adding info to your very first post, Kodiak... that's a great idea!
Thanks! Hopefully it'll find someone in my shoes some time down the road. I plan on doing one for LED bulbs (reverse/cargo/license plate) next!
Posted: Tue Feb 28, 2017 12:47 am
by adeluca73
37x12.5 Nitto Ridge Grapplers, stock wheels, 45psi, 1.5" level: minor rubbing at full lock, didn't even try a spare
Posted: Tue Feb 28, 2017 1:16 am
by TankerZak
I haven't done the spare yet...
Posted: Tue Feb 28, 2017 6:42 am
by Kodiak
adeluca73 wrote:37x12.5 Nitto Ridge Grapplers, stock wheels, 45psi, 1.5" level: minor rubbing at full lock, didn't even try a spare
Nice, first 37 to the party, keep them coming!!
Posted: Tue Feb 28, 2017 9:52 am
by rkgzx9leftcoast
Yeah, I have the 37 X 12.50 Ridge Grapplers on stock rims as well - Tradesman. I have Thuren front level springs on it now 1.5 In, they only rub at full lock on Radius arms, most of the time they dont. It was the same with stock front suspension. I have had it off road, nothing crazy, but it will rub a little at full stuff, nothing too bad though. They measure just a hair over 36 inches on truck mounted with 45 lbs in front. I was really surprised with no trimming needed when I drove it on stock front suspension for a few weeks before I leveled it.
Good thread !!!
Posted: Tue Feb 28, 2017 10:08 am
by Kodiak
rkgzx9leftcoast wrote:Yeah, I have the 37 X 12.50 Ridge Grapplers on stock rims as well - Tradesman. I have Thuren front level springs on it now 1.5 In, they only rub at full lock on Radius arms, most of the time they dont. It was the same with stock front suspension. I have had it off road, nothing crazy, but it will rub a little at full stuff, nothing too bad though. They measure just a hair over 36 inches on truck mounted with 45 lbs in front. I was really surprised with no trimming needed when I drove it on stock front suspension for a few weeks before I leveled it.
Good thread !!!
Post up some pics if you have any!
