Do you daily drive (and long trip drive) your bead balanced tire shod rig?
What brand balance beads are you using, have they been effective?
What quantity are you using per tire?
Are you running them in tires that are known to be prone to imbalance or ones that are known to be well balanced?
Light weight tires or heavy?
^these two are an attempt at gauging efficacy since I would be running them in heavy, hard to balance tires (37x12.50R17 Pitbull Rocker XOR LT radials)
Have you run them for the life of a set of tires?
^when dismounting those tires, did you notice any undue wear on the inside of the tire or wheel?
For those running Hutchinsons, did you notice any undue wear on the beadlock insert?
Thanks y'all!!!!
