Rear leaf spring torque?
Posted: Fri Jan 27, 2017 9:51 pm
by rbpowerwagon
Hey guys! Just got my new Thuren lt leafs but not sure torque on the bolts. Anyone know?!!!
Re: Rear leaf spring torque?
Posted: Fri Jan 27, 2017 10:27 pm
by DamageWagon
rbpowerwagon wrote:Hey guys! Just got my new Thuren lt leafs but not sure torque on the bolts. Anyone know?!!!
Isn't it on the instruction sheet he gives? The back of all of his instructions has torque specs. If not I recall 150ft/lb being recommended. Less is better than more on leaf springs, so they can move around a little easier.
Posted: Fri Jan 27, 2017 10:28 pm
by RAM4ROKS
I cannot find specs for Thuren but I can for Carli, I cannot imagine them differing much. (I edited out some of the Carli specific stuff to streamline this info):
Once both sides of the leaf springs are installed, torque U-bolt
nuts to 110ft.lbs evenly in cross pattern. Install rear wheels, torque to OEM Spec and lower the
truck to the ground.Once truck is on ground, torque the front and rear hanger
nuts and bolts (rear consists of upper and lower shackle bolts) to
180ft lbs.Re torque u bolt nuts to 110 ft lbs once truck is on ground
I can try and find the factory printout I got from my dealer on Sunday if no one has posted the factory specs by then.
Posted: Fri Jan 27, 2017 10:39 pm
by Colibri
Can't be said enough, always torque leaf springs with the truck on the ground!
Posted: Fri Jan 27, 2017 11:36 pm
by rbpowerwagon
Awesome, thanks guys! Didn't get any instructions with these, oh well. Everything is torqued up and ready to go. Them f'ing things are a bitch to get in.
Posted: Mon Jan 30, 2017 12:35 pm
by coder
For a 3Gen (not sure if a 4 Gen is much different) shackel bolts are 170 ft. lbs. and u-joint are 110 ft. lbs.
Posted: Mon Jan 30, 2017 10:01 pm
by rbpowerwagon
Thanks everyone, just ended up going with the Carli specs. These things are wicked!
Posted: Mon Jan 30, 2017 10:20 pm
by DamageWagon
You must have installed them correctly then have fun!
