Yokohama G015 315/70R17
Posted: Sun Jan 08, 2017 2:32 am
The stock Duratracs finally gave out after 25K. Might have gotten another 5K, but the snow and ice made the decision easier. Looked around for a bit trying to decide on what brand. One of my deciding factors is that the tire should have the severe snow rating. The G015 does have it. Next was the size. 285/75R17 was an option, but I didn't want to have 80 psi tires. Since I tow during the spring, summer and early fall months I just did not want to have the rough ride when the trailer wasn't in tow. Max psi of 65 in the 315s made more since. Plus they were cheaper than the 285s!
Tires were mounted this past Thursday. Have had them on packed snow and ice. The Yokohamas have dug in to those conditions better than the Goodyears did when they were brand new. Spend more time in 2wd than 4wd. On road ride has greatly improved. Going over potholes and speed bumps is much smoother. I would say this is due to a wider footprint and more sidewall. Ride is also a little less choppy when going over the expansion joints on the Interstate. Do notice that the 315s are heavier.
Some interesting observations. The eco light comes on way more now than it did with the 285s. Transmission stays in gear longer than before. The big Hemi seems to be happy lugging along between 1400 and 1600 rpms. Not sure about the mileage yet. Temperatures out here in Colorado have been wild. Once it settles down it will be easier to figure out the mpg's. Acceleration and braking haven't changed as far as I can tell.
Like many on here have said 315s fit on the 2014+ trucks as though they should have come from the factory. There is absolutely no rubbing anywhere while on road. Haven't been off-road yet with these tires. I would hazard a guess and say rubbing won't be an issue off-road either. A 315 would fit perfectly in the spare location if it wasn't for the heat shield. It definitely needs to be aired down to fit in there. Lastly, I know if there aren't pictures it didn't happen. They are a coming.
Zane
Zane
