2016 trans chirp when cold.
waldo
Post by waldo » Sun Oct 02, 2016 1:37 pm
Anyone else? Sounds like a belt, but I had the wife get in and put it in drive while I was under it and it sounds like it's coming from the trans or torque converter.
Same noise in drive or reverse, nothing in park.
Dealer changed out the serp belt, but that's not it. They couldn't hear it because it was still warm when they checked.
Re: 2016 trans chirp when cold.
Post by Colibri » Sun Oct 02, 2016 4:26 pm
My 09 with 545rfe did that for years with no problems. I suspect it was the torque converter but I don't actually know.
PWDan
Post by PWDan » Tue Oct 04, 2016 2:53 pm
My 2010 is doing it on hard shifts but only if I have my foot in it. Been doing it for about 5000 miles now and it's definitely coming from the trans. It doesn't seem to slip or anything but gives a loud chirp from 1st to 2nd and 2nd to 3rd. I'm hoping it's not the start of a big problem.
Mrking
Post by Mrking » Wed Oct 05, 2016 12:13 pm
I have a similar noise which is louder when cold but is present all the time. Mostly in 5th 6th gear most noticeable at 55 mph light throttle. See my post noise in 66rfe transmission. Dealer trans guy says normal yet it has gotten worse with higher miles, 17000, and i can hear it occasionally in lower gears at shift point which just started recently. Dealer opened "star case" with Chrysler and they r no help. I'm curious if your concern is the same as mine.
Ed1774
Post by Ed1774 » Thu Oct 06, 2016 8:10 pm
waldo wrote:Anyone else? Sounds like a belt, but I had the wife get in and put it in drive while I was under it and it sounds like it's coming from the trans or torque converter.
I also have this noise..... Jump into truck, start it up, shift into drive, hear chirp in transmission.
It appears I have all the wonky 66rfe noises. The cruising along at 55-60mph whistle noise that goes away with a little upward pressure on the gear shift lever and the start up chirp when placed in drive. Kinda glad i'm not alone on this.
Mod's:
305/70/17 Toyo AT2 tires
Weathertech Floorliners
TSC Toolbox
Carli Diff Guard
TommyG
Post by TommyG » Fri Oct 07, 2016 3:20 pm
Mine chirps when the traction control kicks in. No other times, yet...
AWST1230
Post by AWST1230 » Fri Oct 07, 2016 7:12 pm
My '16 makes a 'warbling sound' when I'm around 20 km/h and light throttle applied. Anyone else notice this?
jjcole620
Post by jjcole620 » Thu Nov 30, 2023 10:14 pm
Did you ever figure it out? Mine is doing the same
