Factory Suspension Skid
Posted: Sun Sep 11, 2016 1:42 pm
by nfb
So I banged up my steering stabilizer last time I was wheeling. Nothing serious, but it knocked the plastic cover loose (talk about a pain in the ass to get back on). While I was looking for pictures to see how the cover sits on the shock, I got to wondering why the steering stabilizer isn't protected to begin with. I found a thread where a 3500 owner installed a "factory" power wagon suspension skid. Part number 82210014
My question is, am I missing a skid plate since I don't have it?
Or did they just stop putting them on the 4.5 gens? I found the skid for $100 on Amazon, does anyone know it it will just bolt on, or should I look in another direction to protect those areas?
Re: Factory Suspension Skid
Posted: Sun Sep 11, 2016 1:58 pm
by pdavey
As far as I know all power wagons come with the
Skid plate. I think you got jipped
Posted: Sun Sep 11, 2016 2:52 pm
by waldo
My 16 doesn't have the skid plate like my 3 gen. But the steering damper is mounted up tight against that giant tie rod.
Posted: Sun Sep 11, 2016 4:38 pm
by laramieskibum
There is a high clearance kit from Carli available I think. Pw comparable I duno:
http://www.dieselpowerproducts.com/p-13 ... 0-4wd.aspx
Posted: Sun Sep 11, 2016 4:49 pm
by OffroadTreks
Yup, my 2015 doesn't have it either.
Posted: Sun Sep 11, 2016 5:52 pm
by blindsquirrel33
My 2011 has it.
Posted: Sun Sep 11, 2016 6:59 pm
by Mr.Smith
This was never meant for PW use, as the PW's sway bar is in the way.
Posted: Sun Sep 11, 2016 8:05 pm
by nfb
Anyone know definitively if that skid will fit the later models, or should I play guinea pig?lol. $100 isn't too bad for a little extra protection.
Posted: Sun Sep 11, 2016 9:42 pm
by RustyPW
Wonder when they stopped putting the skid plate on the PW with the new 3 link suspension? Or if they did at all? All of the older 5 link PW have the skid plate.
Posted: Sun Sep 11, 2016 9:52 pm
by Stickman
'14s were the first year they removed it, when they went to the new front end. '13s and older have them.
Posted: Mon Sep 12, 2016 6:54 am
by Will
nfb wrote:Anyone know definitively if that skid will fit the later models, or should I play guinea pig?lol. $100 isn't too bad for a little extra protection.
I doubt it will fit the newer axles. Here's my 2010 without the plate. About 4" to the left of the pumpkin, there is a tab welded to the axle tube for the plate to bolt to. There is also a tab across the lower control arm bracket on the passenger side has a thread clip on it. Then there's another spot it bolts to on the passenger side.
Posted: Mon Sep 12, 2016 3:14 pm
by Low_Sky
They ditched that skid plate at the same time they introduced the Center Axle Disconnect. Coincidence? I think not. You could probably modify it for use with a little cutting/grinding/welding.
Posted: Mon Sep 12, 2016 9:54 pm
by nfb
For $100, I think it might be worth trying to mod it up.
Posted: Tue Sep 13, 2016 12:45 pm
by pdavey
That is ridiculous they deleted it. If I didn't have the skid plate on that I probably would have gone through 5 already. That skid plate has saved my bacon a few times.
Posted: Wed Sep 14, 2016 12:44 am
by RustyPW
pdavey wrote:That is ridiculous they deleted it. If I didn't have the skid plate on that I probably would have gone through 5 already. That skid plate has saved my bacon a few times.
Remember what mine looked like at Rausch Creek this year.
It was bent up around the tie-rod.
Posted: Wed Sep 14, 2016 10:07 am
by FirerescuePW
I'm in favor of ALL of the skid plates. I have a bad habit of using them as part of the suspension while rock climbing...
Posted: Wed Sep 14, 2016 4:34 pm
by pdavey
Yeah this year I leveraged my control arm for balance. Skid plates are necessary if you use your truck for what it is intended for.
Posted: Wed Sep 14, 2016 6:31 pm
by nfb
pdavey wrote:Skid plates are necessary if you use your truck for what it is intended for.
Seriously! I by no means do anything extreme in my truck, and I'm already seeing that area as a weak spot.
Posted: Wed Sep 14, 2016 7:11 pm
by cruz
pdavey wrote: I think you got jipped
I wonder at times
are they (engineers and bean counters) thinking, why eliminate some thing as simple as that .
nfb wrote: Seriously! I by no means do anything extreme in my truck, and I'm already seeing that area as a weak spot.
Yeah, shit DOES happen , even in day to day driving.
