On-board Air Compressor
Posted: Thu Sep 08, 2016 10:38 am
I did a search but could not find a thread on this so if one exists please point me in the right direction.
First of all, let me make the disclaimer that I'm no where close to making this purchase, I have many upgrades planned that will take precedence over this but I have pretty well made decisions on what those items will be and how much they will cost and this is my next item to research. I like to plan my mods well in advance so hopefully everything works together and I don't waste money on something that won't integrate with future mods.
So I am looking for an on-Board air system that I can use to re-inflate all 4 of my 35" tires from around 20psi to 50 psi+ in a reasonable amount of time without overheating. I would like the ability to run air tools but that's not a necessity . Primary use for now would be airing up Atv tires and trailer tires up to 80 psi as both are prone to slow leaks as well as adjusting the truck tire pressure for drastic load changes. I may also put overload airbags on the truck at some point. I would prefer to mount the unit underbody and to have a quick connect at the rear of the truck so I can reach both the truck and trailer tires with a 25-30ft hose.
Here are my questions:
1) What brand is the best bang for the buck? Viair, ARB etc.
2) Large tank, small tank, or no tank?
3) Is it better to buy a full kit or purchase the pieces separate?
4) High CFM lower duty cycle or constant duty with lower CFM.
5) Best mounting location
Thanks in advance!
Thanks in advance!
