Tire pressure opinions
Posted: Tue Aug 09, 2016 8:31 am
by 65plymouth
I am interested in knowing what tire pressure everyone is running unloaded?
I just put Cooper Discoverer ST Maxx 285/75/17 on my 2016 and am not 100% sure what I should be running. These are load range E tires yet are rated for the same 3195 (approx) Lbs as the load range D tires. The tire shop aired them up to 70 PSI and the truck rode like a cement truck on the way home. I aired them down to around 54 PSI and will suffer with the TPMS light for better ride quality and tire wear.
54 PSI is much better but If I could go down to 45 or 48 I would prefer to.
Just wondering what you guys are running for ride quality and optimal tire wear around town and unloaded?
Thanks
Re: Tire pressure opinions
Posted: Tue Aug 09, 2016 9:08 am
by verdesardog
I run the 31570-17's on my truck at 35 psi around town, 50 when on extended highway or towing a 3,000# trailer.
Posted: Tue Aug 09, 2016 11:14 am
by Will
35 back 45 front for me but your tire maybe slightly different. Get them dirty and drive on a straight road to see the wear pattern (or chalk them) I suspect the outer tread isn't touching in the back with 54lbs, you'll wear out the center of the tire that way.
Posted: Tue Aug 09, 2016 2:06 pm
by israelstanage
Nice article going through Carli's process
http://blog.carlisuspension.com/2015/11 ... y.html?m=1
Factory tires wore fine at the ridiculous pressures they recommend; my toyos were wearing uneven on the back. Finally found a dealer willing to change the factory TPMS thresholds. We'll see if I can manage to run proper psi with no dash lights.
I am running 40 front 35 rear on 35 inch rts
Posted: Tue Aug 09, 2016 2:46 pm
65plymouth wrote:I am interested in knowing what tire pressure everyone is running unloaded?
Thanks
Are they really 285/75/17's, or 285/70/17's? I thought they only made the 70 series.
Posted: Tue Aug 09, 2016 9:18 pm
by Bill2014
To make sure you get the full gamut of responses, I figured I'd chime in. I always run the "ridiculous" pressures that are recommended or max supported by the tire if it's higher. It's true that the ride is a little harsher when empty, but I can't stand the slower steering response with even slightly lower pressures on the highway. My truck pretty much always gets used as a truck to haul or tow something - it's not my daily driver.
You're not going to wear out your tires any faster if you run them near max rated pressure on the road - they were designed, belted, and tested to work that way. Of course if someone gets off trying to spin them all the time on purpose then they're gonna wear out.
Also, if you run a tire on a rim width that it wasn't designed for, it might work, but you also may experience a loss of traction or abnormal tire wear regardless of what pressure you choose.
:cheers:
Posted: Wed Aug 10, 2016 12:20 am
Thanks
Well i will be gol darned, they do have the 75 series. At least on their tire size list on the website.
Posted: Wed Aug 10, 2016 2:39 am
No load, 45 front, 35 rear. With load, then I up the pressure. Can't stand feeling like a basket ball at the recommended pressures when empty.
Posted: Wed Aug 10, 2016 8:01 am
by 65plymouth
Thanks guys... Good info here. Yes, Cooper does make the Maxx in 285/75/17 which is load E. Currently they are on backorder status and I had to search far and wide to get them from a vendor that had older stock. The Rep at Cooper advised that they will be available again 3-4 weeks from now. I didn't want to wait that long. Ended up selling my Duratracs with 200 miles on them to a guy on craigslist for $1000.00. Not too bad as far as I am concerned.
Regarding pressures.... I would love to follow the specs on the tire or the placard on the lock pillar but MI roads are TERRIBLE. As I said, the tire shop aired them up to 70 PSI when they were mounted by that pressure was completely unacceptable. Even the slightest bump and the truck felt like it was going to jump lanes. 54 PSI was better, but I still think less air would be optimal. I had the same tires but 285/70/17 on my 1500 Silverado and ran them at 30-35 PSI around town. They wore nicely and rode extremely well. Given that this truck is heavier, I am going to try 40 in the back and 45 up front. See how that works. I do like the chalk suggestion and may try that. The truck is used primarily as a daily driver and is unloaded most of the time. Just trying to get a feel for what others are doing.
I appreciate the responses. Only been a member here for a few weeks, and so far, the folks on this site have been great.
Thanks!!
Jeff
Posted: Wed Aug 10, 2016 9:14 am
by Colibri
Another option for determining correct air pressure for your situation is to use an infrared thermometer to see what temp different portions of the tread are reaching and adjust pressure up or down until it's as uniform as possible across the tread surface. Depends on how nerdy you're feeling lol
Posted: Wed Aug 10, 2016 4:10 pm
Lets see some pics of these tires on the truck!
Posted: Wed Aug 10, 2016 4:25 pm
by 65plymouth
I will post em up...
Posted: Fri Aug 12, 2016 8:57 pm
by Alakablamo
FWIW... I have a 2005 Ram 1500 (obviously lighter than the PW's), and I run my 285/70R17 Duratracs at 45 front / 40 rear. That gives me the best equalized wear both front and rear when empty or with a light load (bikes and coolers).
Posted: Sat Aug 13, 2016 1:43 am
by azracer
I find the chalk method to work the best. I ended up at 42 front and 37 rear on my 2009 no major winch rigging gear and a full tank. You have to do the chalk test when the tires are fairly new though.
phpBB [video]
Clickable link for Tapatalk
Posted: Sun Aug 14, 2016 5:30 pm
by loveracing1988
50 front, 35 rear unless towing, then 50 all around.
Sent from my Nexus 6 using Tapatalk
Posted: Sun Aug 21, 2016 9:46 pm
by Stickman
Went out and chalk tested my 37" Grabbers today and ended up with 40 front 30 rear. Seems quite low but that made the front wear perfect and the rear still had a little chalk left on the outside edge of the outside tread blocks.
Posted: Sun Aug 21, 2016 10:59 pm
by Colibri
3rd gen crew cab on 37x13.50x17 toyo mt's I do 40psi front and 25-30psi rear street pressure
Posted: Mon Aug 22, 2016 12:28 am
65plymouth wrote:I will post em up...
:nopics:
Posted: Mon Aug 22, 2016 2:06 pm
by gone2
I run 40psi all the way around on my 35x12.5x18 unless I'm towing then I put in 60psi, especially in the TX summer heat.
