2014 rear dampener link?
Posted: Tue Jul 19, 2016 7:53 pm
by joeschmidt
I'm looking at getting thurens new pw front springs and getting a full set of the white body overlands, but what about the 5th shock/dampener on the top of the rear axle? Anyone replace that, and with what? Thanks
Re: 2014 rear dampener link?
Posted: Tue Jul 19, 2016 9:34 pm
by Reloaderguy
No, why? The new rear springs are the same height as the originals.
Posted: Tue Jul 19, 2016 9:42 pm
by joeschmidt
I wasn't doing anything with the rear springs.. Looking at putting new rear shocks on but there is a third shock mounted to the top of the gear housing called a dampener link and that's the one I wondering about. I think it's the 5th link to making the whole rear set up, a 5 link system
Posted: Tue Jul 19, 2016 10:02 pm
by Reloaderguy
Uh no, five link is the four control arms plus the track bar. The dampener is just a dampener. Change your tires and shocks, then throw away the dampener. It seems to help the guys that run factory suspension and max PSI in their tires.
Posted: Tue Jul 19, 2016 10:10 pm
by joeschmidt
Copy that. Thank you!
Posted: Tue Jul 19, 2016 11:13 pm
by adeluca73
Or add 2 more & you'll never experience wheel hop again.... :D
Posted: Tue Jul 19, 2016 11:29 pm
by MoparToYou
I'm one of the guys that added two more dampener links, which really helps with rear axle wrap / wheel hop by the way. I don't think you need to replace it just because you are replacing your other shocks. If you do replace it, be aware that it is one super super stiffly valved SOB, and the new shocks can be a real bear to get on if you don''t have the right technique.
Posted: Wed Jul 20, 2016 12:33 am
by adeluca73
MoparToYou wrote:I'm one of the guys that added two more dampener links, which really helps with rear axle wrap / wheel hop by the way. I don't think you need to replace it just because you are replacing your other shocks. If you do replace it, be aware that it is one super super stiffly valved SOB, and the new shocks can be a real bear to get on if you don''t have the right technique.
They were quite persnickety to add, ratchet straps were a savior! :rockon:
Posted: Wed Jul 20, 2016 10:51 am
by hammer40
Please let us know what you think of the new spring and shock set up.
That is exactly the combo I'm considering as well.
