4th gen winch clutch?
JMOS4
Post by JMOS4 » Mon Jun 13, 2016 1:43 pm
Hi,
I have a 4th gen winch installed on a 3rd gen, no matter how far I rotate (3 o'clock, 6 o'clock or 9 o'clock) the clutch lever it never disengages.
I have only used it a few times, but every time I have to run the line out.
I thought it was supposed to work by disengaging the clutch and I should be able to drag the cable out or am I missing something, this is my first winch so maybe a newbie question
Regards,
Jim
2007 Ram ST 2500 5.7 Hemi 6 speed, Dynatrac Hubs/balljoints, 4th gen winch
1992 Dodge Power Ram
Ed1774
Re: 4th gen winch clutch?
Post by Ed1774 » Tue Jun 14, 2016 8:51 pm
Yes it should disengage. When you rotate the lever it should stop and be "disengaged".
Mod's:
305/70/17 Toyo AT2 tires
Weathertech Floorliners
TSC Toolbox
Carli Diff Guard
Post by Reloaderguy » Wed Jun 15, 2016 10:13 am
Doesn't the third Gen require a reversed clutch?
Post by Will » Wed Jun 15, 2016 10:37 am
I've used the crap out of mine and sometimes I have to bump it to get the lever to fully swing to disengage. Try bumping it out, like unwinding with the controller and then try it. The lever should rotate a full 180 degrees.
Post by Retired BLM Rig » Wed Jun 15, 2016 11:40 am
It may be grease that's gotten thick and hard from non-use. If Will's idea doesn't work for you, try moving the lever into the disengage position and tie off to an immovable object, like a large tree, then put your truck in reverse and just gently nudge against the cable to see if applying more than human force against it will get it to come free. If that doesn't work, it may be time for disassembly and inspection. Good luck!
Trouble Maker
Post by Trouble Maker » Wed Jun 15, 2016 10:34 pm
Reloaderguy wrote:Doesn't the third Gen require a reversed clutch?
Could use the 4th gen winch as long it is mounted with the motor on the pass side. but might require reclocking the clutch end of the housing. would be nice to see pics of what we are trying to diagnose. Should still freewheel if clutch is working though.
Black 09 purchased Dec 21/13
180K kms on the clock
