No lights on diff lock controller
2011bigred
Post by 2011bigred » Thu May 26, 2016 10:23 pm
I just bought my 2011 power wagon and I didn't notice on the test drive but there are no lights on on the diff lock and away bar disconnect controller is there a fuse that could be blown or what?
Re: No lights on diff lock controller
Post by TwinStick » Fri May 27, 2016 10:34 pm
Maybe a blown fuse, maybe a blown light bulb, maybe a dealer trick & they unplugged them because none of that stuff works. Did you buy from a dealer ? I am certainly no electrical expert but if they are disconnected & nothing works, it would seem that fraud was in someones head.
2011bigred
Post by 2011bigred » Fri May 27, 2016 11:18 pm
I did buy from a dealer but they threw in a bumper to bumper warranty with the deal and I checked the fuses and all the connections to the sway bar and axles and everything looks good it's going in after the weekend to have it checked out thanks for the reply
Post by olyelr » Sat May 28, 2016 8:03 am
Those switches are a little higher up than the two bumpers so its probly not covered :lol:
Jk! Good luck getting it figured out, and congrats on the new to you truck!
Mopar6.4
Post by Mopar6.4 » Sat May 28, 2016 8:45 am
Are the lockers working?
2011bigred
Post by 2011bigred » Sat May 28, 2016 9:20 am
I don't think that they are I know that the sway bar isn't disconnecting
Post by TwinStick » Sat May 28, 2016 2:34 pm
It helps to drive slowly over a surface that is a little bumpy, to get the swaybar to disengage or re-engage. But if the lights are not even on all, i doubt anything will work. Keep us posted. I wonder if the smart/swaybar electrical plug got submerged in water & toasted the whole system ???
flattire
Post by flattire » Sat May 28, 2016 6:25 pm
Fuses: I was just checking the fuse block on my truck. ( 2005). It has 2 fuses with 4x4 designation.....28 and 43. 10 amps and other is 25 amps.
This info is on underside of fuse block cover. Your truck is sure to have something similar.
Mopar6.4
Post by Mopar6.4 » Sat May 28, 2016 8:48 pm
2011bigred wrote:I don't think that they are I know that the sway bar isn't disconnecting
You would know if they locked up, you can't hardly turn. Not trying to a be a jerk but it seems you don't know much about your truck. If I was you I'd take it back to Dodge and use the warranty.
Post by TwinStick » Wed Jun 01, 2016 11:41 pm
Any updates on this ?
:popcorn:
2011bigred
Post by 2011bigred » Wed Jun 08, 2016 10:11 pm
They think it's the diff lock sway bar switch on the dash new one going in in the morning will update after that
Post by adeluca73 » Thu Jun 09, 2016 12:30 am
:popcorn: :popcorn: :popcorn:
2011bigred
Post by 2011bigred » Sat Aug 27, 2016 10:45 pm
Sorry for the long just got truck back from forth trip to the dealer they replaced a computer module today and hurray we have lights on now haven't had a chance to test yet however driving to the house I did get the sway bar to disconnect and I switched the rear diff lock and just got a blinking light I'm not sure if something else is broke or if I just didn't get the tires to spin enough any thoughts?
2011bigred
Post by 2011bigred » Sun Aug 28, 2016 12:22 am
I was in 4 low and tried driving in circles a little bit
Post by adeluca73 » Sun Aug 28, 2016 12:29 am
Check the xfer case sensor switch...seems to be a bugaboo for several here W/ locker issues...smart bar needs the 4Lo signal to send 12v to locker solenoid
2011bigred
Post by 2011bigred » Sun Aug 28, 2016 9:38 am
Quick update got the wagon on a loose gravel road this morning and lockers engaged perfectly thanks for all the help
Post by cruz » Sun Aug 28, 2016 12:12 pm
Good deal, I think your dealer is the only one in the country that knows anything about a Power Wagon. :lol:
flattire
Post by flattire » Sun Aug 28, 2016 12:40 pm
Do you know what module they replaced?
2011bigred
Post by 2011bigred » Sun Aug 28, 2016 3:56 pm
Funny you say that because they are pretty terrible usually with service but I guess I found a decent mechanic
