How tall is a BFG 34x10.50r17? Not 34" !
Posted: Sun May 08, 2016 1:20 pm
by flattire
I have been looking for new tires to replace my 2005 spare(!) and 4 2007 BFG's. Wanted to get something slightly taller, slightly narrower for better gas mileage. Ran across the new BFG a/t KO2 ....34x10.50r17. Perfect. Even 3 pounds lighter per tire. Just what I need.
Well, 34" is only 33.5" when it comes to tires. O.K. expected that. Got my set of 5 mounted and balanced and went home. Dealer won't install on truck because not stock size. So, I put wheel on floor with yardstick to measure.
32 7/8" tall .
Yes, that is all you will get.
I want to get same lawyer who is suing Starbucks for $5 million because drink didn't have 24 ounces of coffee because of ice. Just give jury a wheel and a yardstick and let them decide.
Posted: Sun May 08, 2016 2:25 pm
by Low_Sky
You know the bottom of your tire deflects when it's on the ground, right? A 34" tire isn't really going to be 34" high at normal pressure, installed. At the same pressure, a narrow tire will deflect more than a wider tire to achieve the same contact patch to support the weight of the truck.
Re: How tall is a BFG 34x10.50r17? Not 34" !
Posted: Sun May 08, 2016 3:19 pm
by flattire
Measured before they went on the truck. Plus , tire shop must have inflated to 80PSI or something . It pegged my gauge.
Posted: Sun May 08, 2016 3:37 pm
by Cactus Red
Height is measured on a specific width rim. Wide rims equal shorter tires, If you took at the specs, our rims are at the wider end of the recommended numbers.
Posted: Sun May 08, 2016 5:37 pm
by olyelr
Regardless, BFG tires are notorious for running small. The new 37's dont even measure 36", and my 35's barely measured 34". That is with NO WEIGHT of a vehicle on the tire.
Posted: Sun May 08, 2016 5:43 pm
by Will
olyelr wrote:Regardless, BFG tires are notorious for running small. The new 37's dont even measure 36", and my 35's barely measured 34". That is with NO WEIGHT of a vehicle on the tire.
Put 40's on it then, hahaha
Posted: Sun May 08, 2016 5:46 pm
by Will
Measure the radius on the rim laying on the ground. That's what I do to check for clearance prior to ordering. If you can clear 17" then you should be good with a 34, regardless of the total height of the tire, the radius is what counts for clearance. You can still have a 17" radius but from the ground to the center can be much less, like 15", especially running low air.
Hypothetical size mentioned...
Posted: Sun May 08, 2016 5:47 pm
by olyelr
Will wrote:olyelr wrote:Regardless, BFG tires are notorious for running small. The new 37's dont even measure 36", and my 35's barely measured 34". That is with NO WEIGHT of a vehicle on the tire.
Yeah, exactly. Its no issue as long as you get the next size tire up. If you want a true 35, get the 37's.
But, a true 34x10.5 would be pretty frikin sweet... but of course the dropped the ball on that one too.
Posted: Mon May 09, 2016 2:21 pm
by adamdh1
Do you have any pictures? I've been looking to put new tires on my PW and am in between 285/75r17s and the 34x10.5's.
Posted: Mon May 09, 2016 9:37 pm
by flattire
Don't know how to post pic. Probably wouldn't notice much difference unless you knew to look for one.
I like the way they look. Just slightly narrower than stock BFG. I also like the look of the KO2's. Would look even better if a little taller!
They are more expensive than 285/70r17 but I was paying for the extra height which I didn't get. Also hoping for some improvement in gas mileage...taller, narrower, lighter.
Posted: Mon May 09, 2016 9:45 pm
by olyelr
adamdh1 wrote:Do you have any pictures? I've been looking to put new tires on my PW and am in between 285/75r17s and the 34x10.5's.
That is a perfect size, and much better than the so called 34x10.5... but unfortunately they dont offer it in the new KO2's that I know of, yet anyway.
Posted: Mon May 09, 2016 10:50 pm
by adeluca73
olyelr wrote:adamdh1 wrote:Do you have any pictures? I've been looking to put new tires on my PW and am in between 285/75r17s and the 34x10.5's.
Wait oh hell---I noticed someone's signature no longer lists a rubicon, after years of lurkin, you took the dive!
Welcome!!!
Posted: Mon May 09, 2016 11:34 pm
by olyelr
adeluca73 wrote:olyelr wrote:adamdh1 wrote:Do you have any pictures? I've been looking to put new tires on my PW and am in between 285/75r17s and the 34x10.5's.
Welcome!!!
Yes sir I did! Thanks!
Posted: Tue May 10, 2016 7:51 pm
by Mopar6.4
I think this is why I'm going to buy 285/75r17 Toyo MT. Seems to be right at 34" from what I've read.
Posted: Tue May 10, 2016 8:11 pm
by olyelr
Mopar6.4 wrote:I think this is why I'm going to buy 285/75r17 Toyo MT. Seems to be right at 34" from what I've read.
Yep, thats a wonderful size/style tire. As long as you want an mt.
Posted: Tue May 10, 2016 8:36 pm
by Vee
olyelr wrote:Mopar6.4 wrote:I think this is why I'm going to buy 285/75r17 Toyo MT. Seems to be right at 34" from what I've read.
They have the same size in an AT. That's what I have on mine. So far they are working for me.
