Winch
Winch
2015 power wagon. Should my winch free spin when pulling on cable or pulling by hand.
Re: Winch
Check the position of your free spool lever.Gates75862 wrote:2015 power wagon. Should my winch free spin when pulling on cable or pulling by hand.
Re: Winch
I've looked and never found it. I know usually they are on top and I can't feel one up there. Funny thing is I called dealer and asked them and he was I'm not sure on that most power wagons don't come with a winch. I told ok sir you have a good day I'll call somewhere else.
Re: Winch
It's through the bumper to the right between the rollers and the tow hook.
- verdesardog
Re: Winch
hehe most PW's don't have winches, that's funny right there!
- 14PowerWaggy
Re: Winch
It's in there... Just really hard to get to... Its on the driver side on the top... Even harder to get to if you connect the winch hook to the driver side tow hook...
Re: Winch
maybe I can start a stupid debate....
do you guys leave the winch in free spool or engaged when its tucked up and not in use?
Re: Winch
Engaged with a touch of slack. I was told having it pulled tight was hard on the cable, and that made sense. I suspect if you left it in free spool you would end up with slack on the drum that could cause an issue when you went to use the winch. My experience is that the cable can wrap over itself if loose which can thwart pulling the cable out by hand.RamGentry wrote:maybe I can start a stupid debate....![]()
Re: Winch
^^^^^^ All of this! Free spool is only for pulling the rope out. You will end up with a tangled mess, and a damaged rope if you try to use it and wraps are piled on top of other wraps.
Re: Winch
X2 , I take out just enough to keep the hook from being loose on the tow hook.
- Stickman
Re: Winch
I snug my Prolink up just enough to keep it from walking back and forth on the rollers and call it good.
- Cactus Red
Re: Winch
For whatever reason, we find that on both the PW and the JKUR people seem to want to play with the winch when parked at public places. So the JK now has a cover over the winch to keep the clutch lever protected and the ProLink is pulled tight to the fairlead, and I keep the Safety Thimble tight on the PW. It's probably the same people that steal my vavle stem covers...
As fas as the cable or rope goes, I don't try to make it perfect when re-spooling it. I always try to use all of the line except for the last 8 wraps to maximize the pulling power, so it's all coming off the drum anyway.
Re: Winch
Unless in a perfect straight on pull, it'll tend to favor one side. Once I'm done actually using it, I'll pull it all out minus the drum wrap, hook it to a pole or tree or something straight ahead, preferably on a slight incline, and winch the truck to the anchor with it in neutral to get it wound back evenly and tight. You never know when or if you'll need a short pull. I run synthetic rope so its not as bad but a crossed up wire rope (like the factory one) can ruin it in one pull in the right scenario.Cactus Red wrote:For whatever reason, we find that on both the PW and the JKUR people seem to want to play with the winch when parked at public places. So the JK now has a cover over the winch to keep the clutch lever protected and the ProLink is pulled tight to the fairlead, and I keep the Safety Thimble tight on the PW. It's probably the same people that steal my vavle stem covers...
- Cactus Red
Re: Winch
I've used two snatch blocks to shorten the line, or redirect the pull to a farther attachment point. I always try to keep it on the last wrap.
