damaged wheels
Posted: Sat Nov 28, 2015 1:55 pm
by jsemm
I recently got stuck and the mud was up to the frame. I had to winch out and the mud was so deep I needed to spin the tires while winching. I scratched one wheel up very bad from spinning in the rocks. Its a 2013 truck. Is there any way to repair the wheel.
Re: damaged wheels
Posted: Sat Nov 28, 2015 2:13 pm
by RamGentry
Hard to tell wihtout seeing any pics of the scratches. Sometimes polish is enough to lessen or clean up hairline scratches.
Re: damaged wheels
Posted: Sat Nov 28, 2015 3:47 pm
by Will
I got is some bad mud with rocks and did the same but lived with it. The tires balance so... Haha
Re: damaged wheels
Posted: Sat Nov 28, 2015 6:01 pm
by jsemm
Ya its pretty much ruined it took all the finish off and its only on one wheel. Some are very deep.
Re: damaged wheels
Posted: Sat Nov 28, 2015 6:28 pm
by Low_Sky
You can repair scratches to forged aluminum wheels, but you'll go through the clear coat to do it and it's a lot of work. Might be easier to just live with it. It is a Power Wagon, and you earned those scratches doing Power Wagon stuff, after all.
Re: damaged wheels
Posted: Sat Nov 28, 2015 7:19 pm
by Will
Just spray it with Plasti Dip, that's what I did
Re: damaged wheels
Posted: Sat Nov 28, 2015 8:31 pm
by FirerescuePW
Buy one more and use the damaged one for your spare?
Re: damaged wheels
Posted: Sat Nov 28, 2015 8:55 pm
FirerescuePW wrote:Buy one more and use the damaged one for your spare?
That's what I would do. You will spend dang near as much repairing it as you would to just buy another used one.
Re: damaged wheels
Posted: Sat Nov 28, 2015 10:41 pm
by Stickman
I'm with Will, plati - dip it if you don't want to live with it and don't want to drop the coin on an extra.
Re: damaged wheels
Posted: Mon Nov 30, 2015 12:15 pm
by coder
Google for a wheel repair shop in your area they can usually fix most types of damage including sand, polish and new clear coat for a lot less than a new wheel.
Re: damaged wheels
Posted: Mon Nov 30, 2015 12:20 pm
by Mr.Smith
That sucks, let's see the damage...
Re: damaged wheels
Posted: Mon Nov 30, 2015 6:57 pm
by jsemm
I ended up sanding the rim with 1500 grit and polishing it with a drill, Looks a lot better except for a few deep scratches. It really brought the shine back.
Re: damaged wheels
Posted: Mon Nov 30, 2015 7:22 pm
by Will
Must not have been that bad then, mine is missing chunks on the leading edge. Haha
Re: damaged wheels
Posted: Mon Dec 07, 2015 12:24 pm
by jsemm
Looks way better than it did before sanding and polishing but it still has some deep scratches. Im going to wet sand it again and polish it. I think I can make it a little better. I use the truck for what it was intended for. Stuff like this is going to happen.
Re: damaged wheels
Posted: Mon Dec 07, 2015 12:33 pm
by Will
oh yes, that's about what mine looked like.
Re: damaged wheels
Posted: Mon Dec 07, 2015 12:45 pm
by Bill2014
The gouges add character - display it proudly
95% of people with pickup trucks don't even take them off-road.
Re: damaged wheels
Posted: Mon Dec 07, 2015 10:59 pm
by Ducky's Dad
Years ago I damaged a Jeep wheel so badly that it was not safe to drive on. Sent it to a professional wheel repair shop and it came back good as new, not too expensive.
I once needed a complete set of aluminum wheels for a Jag I was doing, and all I could find was a refinished set. Bought them long distance with return option, and they were great. A competent wheel shop can work wonders.
Re: damaged wheels
Posted: Tue Dec 08, 2015 7:15 pm
by jsemm
I don't have a wheel shop close. Im going to wet sand again, polish, then wax. I think I can get it a little better than it is now. I wish I took a before picture because the wheel looked horrible. It was completely dull.
Re: damaged wheels
Posted: Tue Dec 08, 2015 7:41 pm
by MSCH2112
hey, that looks like my wheel!
i've learned if your going to offroad the PW, ya gotta live with the scratches.
Mike
Re: damaged wheels
Posted: Sat Dec 12, 2015 12:56 am
by adeluca73
An orbital polisher with mild grit wet abrasive polish will greatly help with that
